20 Most Recent Jaeger-lecoultre Master Compressor Memovox 1708170 Wrist Watch Questions & Answers
The date changes around midnight and you can usually advance the date by going past midnight until the date changes and then turning the watch backward to a time shortly before midnight and then winding it forward again.
How far back you need to go you will have to find by experiment but it should not be very far.
Jaeger-lecoultre... | Answered on Jun 09, 2011
mcdevito75 here, Sounds like you need the watch serviced, specially if not so in 2 years. Check the repair service directory here at Fix Ya, bottom of the page click on repair service directory then watches.
Jaeger-lecoultre... | Answered on Jun 25, 2010
mcdevito75 here, It does seem to be a hard way to set the date. I would imagine to you have stem and not buttons, Try this slip your fingernail just under the stem (winder) and lift the stem to it"s first position, now turn the stem either toward or away from you to change the date easily.
Jaeger-lecoultre... | Answered on Jun 21, 2010
Your question was cut off please explain your problem further Don
Jaeger-lecoultre... | Answered on Sep 13, 2007
Do you have the model number. That would help you to make some speculations or comparing the recent cost or repair.
Thanks!!
Jaeger-lecoultre... | Answered on Sep 19, 2010
It might be worth having the back of the watch removed to see if there is anything engraved on the movement.
You might find that cleaning the watch gets is going, although the advice of the watch repairer should be asked for on this, as it might be very worn and in need of new parts which are unlikely to be available.
If it works and there is information on the movement, you might be able to get some information on the watch from the maker. Visit their web site (www.jaeger-lecoultre.com/) and make an inquiry, giving them all the information that you have.
An interesting problem!
Good luck.
Jaeger-lecoultre... | Answered on Jan 24, 2010
If you can provide over here the picture of the watch, that would be easy to identify the problem and fix.
Let me know
Jaeger-lecoultre... | Answered on Sep 08, 2009
Take the watch to a jeweler to determine battery type.
Watches | Answered Yesterday
"G-Shock WR20BAR" could mean hundreds of different G-Shock models. If yours is an all digital G-Shock, the answer is fairly simple. When looking at the watch face, the upper left corner button is the "ADJUST" button. Press and hold the ADJUST button for a couple of seconds. You should start to see something flash on the display. Some models will have many options to select in ADJUST mode. To scroll through them, press the MODE button, which is in the lower left corner. You set the hour, minute, seconds, month, date, and year each separately. When you are done, press the ADJUST button again and you'll be back to normal time keeping.
If you want to learn more about your G-Shock, there is something called a "MODULE" inside it that is the brains of the watch. You can find that on the back of the watch, outlined in a rectangle. Usually a 4 digit number. You can download the manual for your watch using that number, if you enter it on a CASIO website:
http://support.casio.com/en/manual/manuallist.php?cid=009
Fixya does not sell watch batteries.
Watches | Answered 2 days ago
Jaeger-lecoultre Master Compressor Memovox 1708170 Wrist Watch Logo
11 questions posted
Top Jaeger-lecoultre Watches Experts
Arturs Kalnins
Arturs Kalnins
Marvin
Marvin
Are you a Jaeger-lecoultre Watch Expert? Answer questions, earn points and help others
View Most Popular
  • Jaeger-lecoultre Watches
Most Popular Question
memovox running fast got now about month
  • Watches
