I would like to connect it to my new phone Lg 8350
BT350 passcode is 4 zeros... > 0000
http://www.jabra.com/Sites/Jabra/ap-en/headsetsupport/pages/Knowledgebase.aspx?kbid=9042862d-c51f-4611-98f6-dfe338dbf3ca
The pass code is 0000 for all of blue tooth
Buy another bluetooth.these unidens kinda **** balls
Passcode is not working for me on my LG Versa with jabra BT350
Try this website: www.abe-hk.com
I have a palm treo and and a bt 350. Press settings/connections/bluetooth/check both boxes; turn on, and make discoverable/click devices tab/turn the jabra off/then hold the ear button till the blue light is solid (not blinking)/click new partnership on the phone/click 0000 for the passcode. it should hook up.
Passcode should be 000 thatt worked for mine
I got bluetooth jabra bt350; my sprint phone has bluetooth but it says nothing about bluetooth devices just bluetooth
Just turn on bluetooth on ur phone and serch for bluetooth devices.When u get Jabra BT 350 pair to it.U will ask for passcode that u get it with ur Jabra BT 350.Put it and it start working.Try changing Accesries options.
Regards,
Sandeep
SOURCE: Bluetooth ear set not being detected by new phone
ok, thanks.
Found the problem. As always "Read the instructions first!"
Bye
SOURCE: Unable to Detect the Jabra BT125 headset from any Bluetooth Device
If you hold down the button, it will turn the light blue, keep holding it till you can connect it. It will come up as Jabra BT125, hit connect. Then it will ask for a password. The password is 0000. Then it will connect :)
SOURCE: Cant connect my Jabra BCE
default PIN is 0000... be sure to turn on BT on your phone first, then power on your jabra... your phone should ask to pair to the jabra and then you enter the 0000
Had the same problem with the BT250v 'connected' to my Nokia 6021. When connected to my notebook, the 250 did produce sound, so decided the Nokia was the problem. Fixed the problem by doing a full reboot of the phone like this:
Jabra: Turn off the 250
Phone: Delete the BT connection to the Jabra (in BT settings)
Phone: Switch off BT
Phone: Turned off the phone (I've even removed the battery)
Phone: Turned on the phone
Phone: Switch on BT
Jabra: Turn on the 250 for detection
Phone: Look for audio devices
Phone: Connect to Jabra
Problem fixed!
i have a bt25r bluetooth headset and lost the manual i need to know how to pair it and the code
i need to know haw to pair a bt25r bluetooth head set i lost my manual and forgot everything
my Jabra BT350 Bluetooth has connected fine for many months. Now I can connect with the same phone.
Don't know what to do?
What happens if i do not the passcode? I have a jabra BT2010...is there any way to reset the passcode?
Has anyone found where we can get the passkey to connect to our phones?
