20 Most Recent
Jabra BT350 Wireless Headset Questions & Answers
I am trying to pair
The numeric passkey is
0000 (4 zeros).
For more details, download the instruction manual in PDF format by clicking this
link.
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from:
http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using
FixYa.
Bt350. Can I increase the
Sorry you cannot increase the input.May be there is more disturbances in the surroundings.Try to speak more louder.Thats it you can do.
Thank you
Dont know how to put jabra bluetooth earpiece it
Start with your headset turned off. Then, press and hold the answer/end button, until the indicator light is steadily lit in blue. It is in paring mode now. Then, make the bluetooth application on the device you want to pair your headset with, search for new devices. After a while, the BT350 headset should appear in the device' screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros).
By the way, if your headset's user manual happens to be missing, feel free to download it from
this location.
Hope it works for you.
Regards,
Carlos
BT350
try turning bluetooth off . first erase bluetooth connections on phone. turn off phone and take out phone's battery for ten seconds. put battery back in and turn on phone. plug bluetooth into charger for ten seconds and unplug it. try re-pairing bluetooth with phone. This worked for me!
Vibration on an ear piece
Press and hold the volume down button, then turn the device on by pressing and holding the call button. Now release both buttons.
Bt350
I've gotta solution for you. I had the same problem and what I have found out is that if the headset does not go charged for an extended period of time, the battery needs to get kick started so that it will accept a charge. In order to do this, you have to remove the blue plate with a small screwdriver first. Then with an extremely small torx bit take off 2 screws that were under the blue plate. Next remove the board from the shell, but not so much as to disconnect them from the soldered components.
Here's the tricky part. You will see the 150 MAH NiMH battery with a + and - post right on top of it. the connections are about 1/8" thick. You MUST HAVE a battery charger that can manipulate the current and voltage while charging. This would be like a peak charger for an R/C car of which I happen to have. Set it at 150 MAH, and Delta Peak at Auto and in 10 minutes its charged and ready to go. After you put it all back together, you can then again charge it as you normally would with the AC charger or USB connection. I believe the majority of DOA headsets are due to being on the shelf for an extended period of time and not getting some charge.....eh it happens!
Gerald
