To reset the rainfall Press Set 4 times so the rainfall amount is flashing. Change the rainfall indicator to Total, then hold down the set button for 3 seconds.
Hi, the meter flashes oil change when they are due(at pre-programed intervals) and will stop flashing two running hours after flashing starts. The hours that are showing are total running hours from new. Hope this helps, regards Phil.
My Oregon Scientific Weather Station RGR122: The total rainfall and rainfall windows won't stop flashing. I have removed the new batteries several times, changed batteries in outside collector, and reset the inside unit multiple times. What can I do to solve this problem. Frustrated! Darla
Not sure this is the solution..but the same thing happened to me several times over a few month span. After many attempts to fix a number of items (alternator, etc.), I was told that there was a problem with the radio, and that it had to be "factory reset." My local dealer got some kind of code from Ford and fixed the problem. I haven't had a problem for over a year.
go to the normal time setting, where nothing is flashing. then press and hold reset. then the time you want the alarm on shows up. in order to turn the alarm off press start...press start again to turn it on
