KitchenAid KSM150PS Artisan Series Stand Mixer Logo
A
Anonymous Posted on Jan 28, 2014
Droopy head on Kitchaid Stand mixer - KitchenAid KSM150PS Artisan Series Stand Mixer
Ross Keen
Level 3:
  • KitchenAid Master 1,365 Answers
  • Posted on Oct 07, 2019
Ross Keen
KitchenAid Master
Level 3:
Answers
1365
Questions
0
Helped
583552
Points
2445
Raise the head and adjust the screw that is now exposed from the front over the top of the bowl where the head hinges on the pedestal. Screw out to raise the head up.....anti clockwise.
2 Related Answers
Anonymous
  • 235 Answers
  • Posted on Nov 04, 2009
SOURCE: Question regarding KitchAid mixer, Model K45ss. excessive noise.
Maeveda, Congratulations on your 30 year old KA mixer! Was it a wedding present? Do you still have the K45SS Parts List? If not, you can download a PDF version from the KA website. Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number (in your case, use K45SSW select Parts List (1) and then check to see it this matches your mixer). You can check on page 4 & 5 for the disassembly and reassembly of your mixer, along with all the parts. It will be messy but gratifying. Once apart you can check for any other unseemly wear and tear on the gears, etc.
As far as parts go, here are four potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com (this vendor the best prices for my wife mixer's parts, but sadly they had to back order them, which was disappointing to SWMBO). Prices for the same part vary widely between vendors, so do your comparison shopping. Here's a link to a site that details the disassembly and replacement of a mixer's grease, which might be helpful, too. http://www.foodonthefood.com/food_on_the_food/2009/04/how-to-repair-a-kitchenaid-mixer-yourself.html
Good luck and have fun. I hope this helps. Howard, Burke, VA
Anonymous
  • 130 Answers
  • Posted on Mar 31, 2010
SOURCE: My kitchenAid stand mixer is leaking oil. How do I
referring to:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%204176924.pdf
You can see that there are 5 screws holding the upper and lower gearcase together. They pinch the gasket number 26 together and prevent the oil and grease from leaking. Remove the chrome ring by prying gently around the ring. You will see the 5 screw heads. Tighten them and the leaking will stop.
If it still leaks then you may have to replace the fiber washers number 29 which will involve disassembling the lower gear case.
My kitchaid mixer works just fine but if I have a heavy dough in the bowl the bowl will not stay in the stand. Can the plate be replaced?
You have not mentioned a model number but all the more expensive K/A mixers will have all parts available providing it is not so old as to be obsolete. If you are talking about the base plate I have in my mind then it is only held on with 3x screws so easily replaceable once you have purchased one. It helps for us who answer these questions to have a model number and a country, I'm in New Zealand.
Sep 01, 2014 • Food Mixers
2answers
Kitchenaid stand mixer head wobbles
Hello there,
Sorry to hear you are experiencing an issue with your appliance, please see the link to help page below to help you resolve this problem:
Knob for kitchaid stand mixer
I am assuming you mean the little black knob on the speed control has broken off. I will post the solution for that problem.
The speed control lever on KitchenAid mixers has a little black knob on the end (in some cases this may be white or gray). The knob is pressed onto the lever, so if the knob breaks off your only option is to replace the whole lever.
KitchenAid has a kit that will include all you need to replace the speed control lever. It even comes with instructions. Here is a link to the speed control lever kit on our website: http://www.mendingshed.com/kaleverkit.html
The lever kit includes the speed control lever (with knob), speed link, spring, instructions and a gearbox gasket.
The instructions will only walk you through how to hook up the speed control lever, so if you also need a little guidance in taking the mixer apart, and reassembling it please use the KitchenAid service manual. The manual will walk you through all of the repairs you may need on your mixer, including how to take the mixer apart and put it back together. Here is a link to the service manual: http://lib.store.yahoo.net/lib/mendingshed/kitchenaidservicemanual.pdf
Remember, The Mending Shed is a Authorized KitchenAid service center, we can help you with any repair needs for your KitchenAid appliances, plus all of the parts we carry are genuine KitchenAid brand.
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
Kitchen Aid flat beater leaves carbon on my hands and food
Are you using the white coated beaters or the burnished beaters. If they are the white coated beaters then the finish has come off and the zinc/underneath is rubbing off. Are you using the aluminum looking beaters in heavy acidic applications? if the mixer is new go to kitchaid customer support they will re-place. if your mixer is out of warranty then you need to replace it. about 15.00 t0 24.00 USD. if the problem persists then you may be leaking metal shavings from the planetary head, (I don't think it is happening but it is a possibility) if it is ground metal shavings you have a serious problem. I can't say anymore without knowing more. What application are you getting this result. is it all the time. is it after the mixer sits along time. need more info.
The head of the mixer seems to dip to deep into the bowl. It is scraping the bottom and chipping the attachment.
Hi, Put your mixers head in upright position and adjust the screw between the head and the stand. This will rise the head (one rotation is about 1 mm) and the attachement will not scrape the bowl.
5helpful
My kitchaid artisan mixer vibrates and shakes when in use. what is the problem?
Hi CHRISTIAN649, Merry Christmas and Happy New Year! Based on your description of the symptoms you mixer exhibits, I would say that your head locking mechanism (or a component) of it is either broken, worn or loosened due to normal wear and tear and needs to be readjusted (or repaired) to keep your mixer head stationery.
The inspection and troubleshooting of the inside of your mixer is a DITY capability, particularly if your mixer is out of warranty. Just be sure to have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website a http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> and enter the 6 character model number, in your case KSM150P and select this file KSM150PSWH0.pdf (773.44 KB)listed under Parts List (61). (Check to see if this matches your mixer model).
This parts list manual provides an exploded view for the disassembly and reassembly of your mixer, along with all the part names and numbers. Turn to page 5, titled: Base and Pedestal Unit and locate Illus. #11, Link & Lever Latch Assembly (including Illus. Nos. 10, 12, 13,14, 15, 16, and 17), which locks the mixer head to the pedestal when you run the mixer. Check to see if something is just loose, exceedingly worn or broken. If something has broken, you can order replacement parts and install yourself.
As far as parts go, here are four potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com. Prices for the same part can vary widely between vendors, so do your comparison shopping.
Once apart you can check for any other unseemly wear and tear on other mixer components. It can be messy but quite gratifying to diagnose and repair your mixer yourself.
Finally, here's a link to an excellent site that details the disassembly and replacement of a mixer's grease, which might be helpful, too. http://www.foodonthefood.com/food_on_the_food/2009/04/how-to-repair-a-kitchenaid-mixer-yourself.html
If you feel this is beyond your capabilities and would be too difficult to do yourself you can take your mixer to a local small appliance repair shop and have them troubleshoot and fix your mixer. KA Customer Care can provide you with the name and phone # of the closest authorized KA repair shop in your area or you can do a Online web search, but be sure to get at least three estimates before deciding to commit to one repair shop. Good luck. I hope this helps. Howard, Burke, VA
If this solution has helped you, please rate it, thanks! - hslincoln
1helpful
Kitchenaid artisan mixer does not turn the blade at low speeds
If it is the worm gear then the planetary will stop turning when there is a load on the paddle but the motor will continue to run at the speed you set it at. I'd be checking the carbon brushes, checking that the field assembly has not loosened up a bit and then I would see if the speed control plate adjustment screws are loose. I'd then reset the speed and see if it stays as it should be.
Kitchen aid mixer
It sounds like it is the Control Switch. call up KitchAid and tell them what happened. Seems to be a common problem with them.
Kitchaid 300
Hi Have nice day
At the link below you can find usefull informations and step by step instructions to repair it.
http://home.howstuffworks.com/how-to-repair-small-appliances4.htm
does it help?
Top KitchenAid Food Mixers Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
