Samsung HLR5067WX 50" Rear Projection HDTV Logo
Posted on Jun 01, 2009
Television shuts itself off
Television shuts itself off. sometimes runs ok for a couple days, then shuts self off. sometimes will shut off 5 to 10 times within a half hour. my model # HLS5086WX/XAA, 50 inch rear projection high def.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 17, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1451
Points
I had the same problem with my set shutting off and was told it may be the ballast so i changed that but it still would start up and shut down after a few mins, then i was asked if the bulb had been changed and i had not, so i did change the bulb and have not had it shut down yet. :) (so try a new bulb)
Lg32lh250 shuts off by itself
Look for any jammed remote buttons. Possibility is that some components in the board are either leaky, or there are dry solders in the board.
Unit self powers down.
ok! maybe you have lost contact at the PCB you can re solder the PCB thats why the oscillation is not working.
Tv shut off on its own
Replaing the lamp will fix this problem most of the time.If not count the blinks. This is an error code.
2answers
I have a Samsung FPT5084 Plasma TV and it keeps shutting off
It could be the power PCB, but it is hard to say over the internet.
I am looking for one with a good screen since mine got cracked (don't ask LOL) so if you are interested in selling it let me know.
Thanks
yrk2.7t AT (replace with @ symbol) gmail.com
Vizio shuts itself off
I have found that turning off the power for awhile will work as a temp fix for a couple of days and then just repeat the process.
Mitsubishi Big Screen VS-45607
probaly bad wiring or shorts in the wires or something is intefearing with your tv if it is wiring it might be a fire hazard
Mitsubishi VS-45607
Do self test first goto www.ctechnicians.com
2answers
Closing itself down DEW
camcorder when turned on flashes in red DEW and closes it self down. i have taken all the batteries out and replaced sometimes after a few days the camcorder will work then DEW will rea ppear and shut itself down
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
