20 Most Recent Samsung FPT5084 50 in. Plasma HDTV Questions & Answers
It wont turn on it makes a clicking noise when i
A common problem for this is a bad capacitors on the power supply board. This is why you are hearing the click sound and also turning off. There might also be some other bad component on the power supply board which is making it defective.
If you know about TV repairers, I would suggest that you open the TV and read the power board/panel with a meter, detect the bad component and replace it. Take note that TV stores a lot of current that can shock, so leave the TV for a while before you open it.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you.
Good luck.
7/15/2016 6:16:34 PM • Samsung FPT5084... • Answered on Jul 15, 2016
Samsung tv clicks does not turn on
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
5/6/2016 8:18:06 PM • Samsung FPT5084... • Answered on May 06, 2016
Tv has picture but no sound. which board may be bad?
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience. http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/
7/13/2015 2:22:24 PM • Samsung FPT5084... • Answered on Jul 13, 2015
3answers
Thin black line
Try to replace the YSCAN board. If not fix it, then it's the PDP Panel failure.
2/6/2014 1:38:55 AM • Samsung FPT5084... • Answered on Feb 06, 2014
0answers
0answers
Hi I have samsung plasma fpt5084 I have snowy
adjust vs and vsc voltages when tv is hot let tv fonction for a lease 3 hours if voltages do not fluctuate normally
replace y board
10/26/2013 9:22:04 PM • Samsung FPT5084... • Answered on Oct 26, 2013
Toshiba Plasma TV 50HP95 while watching TV screen
Blinking of the power button denotes an internal circuit fault. If you wish to get more about the blinking codes to Samsung TVs, check this link. http://electronicshelponline.blogspot.com/ Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option
9/24/2013 3:53:19 PM • Samsung FPT5084... • Answered on Sep 24, 2013
2answers
SAMSUNG FPT5084 blows
Here is where to buy the fuse: The fuse with the part number DH81-11975A is compatible with the TV. http://www.samsungparts.com/Products/Parts_and_Accessories/PID-DH81-11975A.aspx?oldpart=Z12AFUSE&model=FPT5084 I think the holder might be available here too:
1-800-627-4368 from Mon - Fri 9:00 AM ~ 8:30 PM EST.
7/22/2013 3:09:41 PM • Samsung FPT5084... • Answered on Jul 22, 2013
6answers
I have a 50 inch Samsung, Model FPT5084X/XAA that won't turn on.
Do not bother replacing the whole power supply for just a few well known bad capacitors on it!Just get quality ones (both better quality *and* higher breakdown voltage) and you won't have this problem ever again...well at least for sure not before a tons of other issues.See here:http://blog.coppelltvrepair.com/2013/07/samsung-fp-t5084xxaa-dead-no-response.htmland here:http://www.coppelltvrepair.com/p/517/samsung-fp-t5084xxaa-power-supply-repair-kit-for-dead-or-shutting-down-boardHope this helps!
7/18/2013 8:30:30 PM • Samsung FPT5084... • Answered on Jul 18, 2013
Samsung FPT5084 50 in. Plasma HDTV Logo
98 questions posted
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
View Most Popular
  • Samsung Televison & Video
Most Popular Question
samsung ongoing power supply problem
  • Televison & Video
