Roland Juno-g Synth Junog 61 Key Proaudiostar Logo
A
Anonymous Posted on Jan 22, 2014
Error 1 display eror 1
Shiv Raj bhatt
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Mar 12, 2019
Shiv Raj bhatt
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1189
Points
7
Sir errar 1 problem is my keyboard how to repair it's a Juno g keyboard error 1?
I have a Behringer Xenyx 1204FX and the DSP Display doesn't illuminate (but works by pressing down and turning the knob). Any idea why it's not on? Also the AUX 1 Send doesn't seem to be working
It sounds like you're experiencing a couple of issues with your Behringer Xenyx 1204FX mixer. Let's address each of these problems separately:
  1. DSP Display Not Illuminating: The fact that the DSP display works when you press down and turn the knob suggests that the issue might be related to the display itself or its connection. Here are a few steps you can take to troubleshoot the problem:
    • Check Power Source: Ensure that the mixer is receiving proper power and is turned on. Sometimes display issues can be caused by power-related problems.
    • Connection: Make sure the ribbon cable or connector that connects the display to the circuit board is properly seated. A loose connection could be causing the display to not illuminate.
    • Faulty Display: If none of the above steps work, there might be a problem with the display itself. You may need to contact Behringer support or a professional technician to get the display repaired or replaced.
  2. AUX 1 Send Not Working: If the AUX 1 send is not working as expected, there could be several reasons for this:
    • Routing Settings: Make sure that the AUX 1 send is properly routed to the desired destination. Check the routing options on the mixer to ensure that the signal is being sent to the correct output or destination.
    • Level Controls: Verify that the level controls for AUX 1 are set correctly. Make sure that the AUX 1 knob for the specific channel you're working with is turned up.
    • Effects/Processing: If you're trying to send a signal with effects applied, check if the effects are set up correctly. Sometimes, an incorrect effect or routing setting can affect the AUX send.
    • Cable and Connections: Ensure that the cables connecting the AUX 1 send to external devices (such as monitors or effects units) are functioning properly and securely connected.
    • AUX Master Level: Confirm that the AUX 1 master level (usually located on the main output section of the mixer) is turned up to an appropriate level.
If you've gone through these troubleshooting steps and the issues still persist, it might be a good idea to consult the user manual for your Behringer Xenyx 1204FX mixer for further guidance. If the problems continue, you may need to reach out to Behringer support or consider seeking assistance from a professional audio technician or repair service.
Recording problem
1. Press and hold down the ASSIGN A button (the light should be blinking) then (simultaneously) press the REC button above channel number 1. The light should blink when you do this.
2. Release the ASSIGN A and the REC button
3. Press the REC button above channel 1 (the light should be blinking by itself)
4. You should see the meters moving with in the display above Input A and Track 1 when you speak into the microphone.
5. Press the REWIND button twice until the display reads ABS 00.00.00.00
6. Press and hold the RECORD button and press the PLAY button. The REC light above channel one, the PLAY light and the RECORD light should become solid.
7. After recording press the STOP button.
8. Press the REWIND button twice until the display reads ABS 00.00.00.00
9. Press the PLAY button.
1helpful
Internal error
Hi, Does the error actual say anything?
Have you tried a factory reset ? Hold down top white key while turning on.
Analog test eror onroland td5
I have the same problem with my module and I can\'t find the solution anyware for the thing.Closest solution that I could find is something about Roland power adapter.Apparently module won\'t work with any adapter with the same voltage,only Roland or Boss B.R.A. adapters works.I have original Roland adapter and still shows an Analog test error.
Have you find the solution in meantime by any chance?
I HAVE A ZOOM MRS-802 B. IT will not start up. keeps reading HDD eror. Can not scan disc due to this reading pops up after step 1 of BASIC MAintenance Procedure. Does not go to ExtFunc pops back to...
Mine did the same thing. Just by chance we had a universal laptop power supply unit with interchangeable tips made by powertran & my wife said to give it a try. The unit has a display window on it & it reads 16.9 volts when the zoom is running. When I plugged it in I couldn't believe it was going through it's start up menu. On the package it says 15 - 20 volts DC 90 watts & I reckoned it shocked the zoom into working again...well anyway, it worked & the zoom is running again. The power box package cost $89AU that I got at an electronics store.
Jan 30, 2011 • Zoom Music
3helpful
On my yamaha v50 keyboard there is another sound on the keys after the c3 key how do i turn it off to just leave the synth sound?
you must do master reset!
1) Turn on the power.
TIP: All buttons must remain depressed and be pressed in the order mentioned in step #2 for proper execution.
2) Press and hold down the [SEQ] button, then the [CARD] button (located next to the Demo button), and then the [DEMO] button.
3) Continue to hold the buttons down until the dialog box appears in the display. The display will first indicate the V50 Test Program and Main Rom Version then will automatically display the question: 'Test Entry Manual?'
4) Press the [DEMO] button. The screen will display: 'Factory Set?'
5) Press the [+1/YES] button. 'OK' will appear beneath the 'Factory Set?' readout, indicating completion of the Factory Reset, and the V50 will automatically return to Play Mode.
9helpful
Pedal Malfunction RP250
You will have to recalibrate your pedal. If you don't have your manual anymore try going to www.digitech.com. The procedure for the RP350 so that you don't lose your presets is : 1. Press and hold the UP/DOWN Footswitches until PDLCAL appears in the display (BYPASS,TUNER and EXIT will be displayed before PDLCAL is accessed after about 5 seconds). 2. When the display prompts you with TOEDN, rock the EXPESSION PEDAL forward (toe down) and press either FOOTSWITCH.
3. When the Display prompts you with TOE UP, rock the EXPRESSION PEDAL back (toe up ) and press either FOOTSWITCH.
4. The Display now prompts you to calibrate the V-Switch sensitivity (VSWxxx), where xxx is the current V-switch threshold. Rock the EXPRESSION PEDAL forward and press firmly on the toe once to turn the V-switch on (WAH ON) and again to turn the V-switch off (WAH OFF).
5. If the V-switch is too sensitive, press the right UP FOOTSWITCH to raise the threshold (range is 0-2000. Keep testing the V-switch sensitivity and adjust the threshold until it only engages when you want it to ( too sensitive a setting will lead to the V-switch falsely triggering on or off when using the Expression Pedal).
6.When the V-switch sensitivity is set to your satisfaction, press both UP/DOWN FOOTSWITCHES simultaneously to exit. NOTE: IF the DISPLAY shows ERROR, an error has occurred and steps 2 through 5 should be repeated. Sorry fo the caps but thats how the instructions appear in my sons manual. You can also dowload the manual and an editor librarian (for the 350 at least) at their site. They might even have an update for your pedal. Hope this helps. Keep playing.
Jul 09, 2009 • Music
Top Roland Music Experts
NOEL
NOEL
Are you a Roland Music Expert? Answer questions, earn points and help others
