20 Most Recent
Tascam DP 008 Digital Portastudio Questions & Answers
Recording problem
1. Press and hold down the ASSIGN A button (the light should be blinking) then (simultaneously) press the REC button above channel number 1. The light should blink when you do this.
2. Release the ASSIGN A and the REC button
3. Press the REC button above channel 1 (the light should be blinking by itself)
4. You should see the meters moving with in the display above Input A and Track 1 when you speak into the microphone.
5. Press the REWIND button twice until the display reads ABS 00.00.00.00
6. Press and hold the RECORD button and press the PLAY button. The REC light above channel one, the PLAY light and the RECORD light should become solid.
7. After recording press the STOP button.
8. Press the REWIND button twice until the display reads ABS 00.00.00.00
9. Press the PLAY button.
Just ran out of card space in my unit and I still
You should be able to remove the card and plug it into your computer... you might need an adapter.
Other than deleting to get space on the card there is not much else you can do. Replace card with larger... it can go to 32Gb. Remember to format a new card beforoe use.
Every time I try to Export a mastered track it
Several of my music programs seem to have a limit of around 2Gb for a track... this is inspite of having plenty of disk space... this seems to be a limit set by the program rather than the resources available.
12/2/2010 6:12:29 PM •
Tascam Music
Answered
on Dec 02, 2010
What does it mean when u get a service error on a
I recommend contacting Tascam at this link:http://tascam.com/contact/support/ Describe your problem. As far as I can tell there were some problems with the media you could use. This article might help:http://www.sweetwater.com/forums/showthread.php?10128-Tascam-CD-RW5000 You could also try contacting Sweetwater Sound and ask:http://www.sweetwater.com/sweetcare/ They have a great staff.
10/19/2010 2:31:14 PM •
Tascam Music
Answered
on Oct 19, 2010
Question- Can I record songs or musics
Here are some good links for you:http://audacity.sourceforge.net/ ( Audacity is a free recording program ) also:http://www.reaper.fm/ ( Reaper is the software I use and is full featured and worth the licence fee and free to try) also:http://www.recordingreview.com/ ( excellent site to answer all your recording questions. Note the free download.)
8/30/2010 10:19:39 PM •
Tascam Music
Answered
on Aug 30, 2010
TASCAM CD-D4OOO
If you are trying to copy disks that are copyrighted, the unit is likely locked out with copy protect firmware from doing copies.
3/17/2010 4:44:20 AM •
Tascam Music
Answered
on Mar 17, 2010
How to with tascam dp-02 dp-02cf
You can use headphones or monitor speakers that are hooked to an amp. If you don't have one ,consider downloading a manual:http://www.tascam.com/i-3582-232-128-1-4A000F90.pdf Pay attention to the caution on page 9 and the hookup diagrams are on pages 12 and 13. Hope this helps.
1/25/2010 10:38:07 PM •
Tascam Music
Answered
on Jan 25, 2010
I want to know how to set up a master on my tascam dp02
first set the in and out points of song make sure your holding down the shift key while setting in and out points.then pres shift key holding down on it pres master key it should start flashing.then pres record play.good luck
9/15/2009 3:55:11 AM •
Tascam Music
Answered
on Sep 15, 2009
Peavey cs1000 x
The most likely case is that one of the main output transistors (if which there are many) is shorted. When the protect circuit senses DC on the final output, it will not allow the output relay to come on to protect the speakers from raw DC. With the power removed, you can check between each outputs Emitter and Collector and you will probably find close to zero ohms. From that point you need to unsolder each of the pins of the bad channel until you find the shorted device(s) and replace them.
2/7/2024 9:32:20 AM •
Music
Answered
on Feb 07, 2024
