Top rack has 3 rusty spots - 1 real bad. Dishwasher is not more than 3 years old. I'm sure its $300 to replace top rack even thought it is fine other than the rusty spots at the front of the rack. Is there some type of paint or knobs that can go over the spots so I won't get rusty dishes?
Any help would be appreciated. Thanks, Kathy
Looks like you can get the upper rack for about half that, direct from Sears-
Dishwasher Dishrack Upper Part Number 8539234 Sears PartsDirect
Still kinda pricey if you only have a few bad spots.
There is special touchup coating (never tried it myself, but looks like it gets good reviews, and the price is right)
Amazon com Rerack Dishwasher Rack Repair White 630076 Home Improvement
Or prong covers if you just have rust or damage on the tips (I've used ones like these, the long ones stay on good)
Amazon com Home Dishwasher Prong Caps Set of 20 Kitchen Dining
SOURCE: Rusty dish rack
Clearly a design or manufacturing flaw. I have the same model and the rack is disintegrating after 6 years. I believe it is a manufacturing flaw. Our previous dishwasher rack lasted over 20 years in the same conditions. Same construction, vinyl covered steel. New upper and lower racks cost over 200.00 and there is no guarantee that this won't happen every six years. I recommend a new non-Maytag dishwasher as soon as you can. Meanwhile, limp along with the defective racks.
SOURCE: I have Kitchen Aid Dishwasher
I removed the tracks from inside the dishwasher. Then I was able to carefully remove the endcaps (something I had not been able to do previously) carefully. The existing broken wheels slid out and I slid two new brackets into each track. If I attached the tracks to the rack first, I would not be able to clip them into place, so I first replaced the endcaps and then returned the tracks to their positions inside the dishwasher. Reattaching the upper rack is not difficult, but takes two people while I connected the left side, my assistant supported the rack on the right side. I then connected the right side of the rack. I slide the rack back and forth to macke sure that is worked smoothly. We then loaded the dishwasher and washed our dishes as we had in the past.
SOURCE: kitchen aid dishwasher doesn't clean dishes in the top rack
Sounds like you have 1 of 2 problems. Either your pump is clogged or you need a bigger drain loop.
replace the top spray arm and it should work ok again
