Mitsubishi Diamond WD-65831 65" Projection HDTV Logo
y
yamaha83 Posted on Jan 22, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Popped lamp, rapid clicking after replacement
When watching TV we heard a very loud pop and so i figured it was the lamp, i just replaced it and the old lamp was in pieces, little pieces of glass moving around inside. I just put in the new lamp and turned on the TV and now when i tries to turn on i hear some rapid clicking and or grinding. not the normal clicks you hear when turning on the TV though. the TV tries to turn on a couple times then turns off and i see no indicator lights that could be used to troubleshoot. anyone have any ideas?
Level 3:
  • Mitsubishi Master 19,187 Answers
  • Posted on Jan 22, 2014
Mitsubishi Master
Level 3:
Answers
19187
Questions
0
Helped
4346376
Points
82261
Take it out and get in there with a vacuum. There are fans that keep it cool and there is a color wheel that might be damaged. All those shards need to be removed
4 Related Answers
DLPDan
  • 9 Answers
  • Posted on Apr 20, 2009
SOURCE: T.v. clicking and wont turn on..
Hello:
The loud pop you heard is usually indicative of a failed lamp. The clicking noise you hear is likely the ballast trying to turn the lamp on.
If you need assistance with a new lamp, please feel free to contact us at www.dlplampsource.com or 866-764-5822.
Regards
Dan
lauracalla
  • 3 Answers
  • Posted on May 07, 2009
SOURCE: Mitsubishi WD-62525 timer light keeps flashing after lamp replace
There is a tiny reset button to the left of the timer light. Press with a pin or something small, wait 60 seconds. Viola!
Anonymous
  • 80 Answers
  • Posted on Sep 17, 2009
SOURCE: TV will not turn on
you either have leaky capacitors near the voltage regulators, cooling fluid leaking on the boards, and/or bad solder connections on the yoke plugs. this model is known for all 3 problems, but you probably need a qualified tv repairman to fix this right.
Anonymous
  • 4090 Answers
  • Posted on Jun 10, 2010
SOURCE: My tv made a loud pop and the screen flickered
You have a damaged sustain board or color engine. All 3 boards should be replaced and retuned. This is not a DIY, although many do try it they end up paying more than having it fixed right the first time. Take the tip, call in a professional and save money.
parts $400 + 2 hrs labour But swapping boards does not fix it and in fact can blow them again.
Please rate my help++++Thanks for using FIXYA
Had a loud snap when watching then no power.
TV repair, clicking and will not power on, loud snap, no ...
? 13:57
https://www.youtube.com/watch?v=UKoR7pWAHzk
Nov 25, 2014 - Uploaded by Robert DIY
TV Power board replacement - 30 - 60 minutes ($20 / $110 / $250 / Replacement) This video will show you ...
Samsung LCD 46 Pop! Then Dead! - TV Forums
www.tv-forums.com/...Repair.../Samsung_LCD_46_Pop!_Then_Dead!_...
Nov 23, 2011 - 7 posts - ‎3 authors
While watching TV, I heard a loud pop, then the tv went dead. ... Ok, so I tested the fuses and the main fuse, by the power plug, had no ...
Samsung power defect causes some TVs to fail, and a class ...
www.cnet.com > Home Entertainment
CNETFeb 14, 2012 - A defective capacitor in some Samsung LCD, plasma and DLP TVs is causing the ... The LN-S4051D is one of the TVs Samsung admits has issues ... In a February 9 report entitled "More than 7 million Samsung TVs plagued by possiblepower defect", ..... Today I heard a loud pop and now I have no picture.
I have a 60" Sony
It seems lamp/ bulb popped again, check lamp inside tv.
If tv does not show red blinking light then it would be lamp that knocked off, replace lamp in tv to fix its problem, please buy Sony original lamp for good picture in tv.
Let me know if you have additional question.
Thanks.
2helpful
I heard a loud pop and my TV went black this morning, can you tell me what the problem might be?
It sounds like your TV lamp popped this lamps are rated for 6000-8000 life hours witch is a average time of 2-4 years take the lamp out I'm sure you will see broken glass inside the lamp I found the lamp you need
http://www.discount-merchant.com/SearchResults.asp?Search=WD-73735
I was watching t.v. Heard a loud pop and the t.v.
Sounds like the lamp popped. If you can find a tech pub on how to take it apart, or are gullable enough to tear into it, the lamp should be found for around $150. Maybe less. But you can also get a new 32" for under $400 too.
1helpful
No Picture, Power light Blinking 3 times then repeats
3 times blink shows lamp cover is removed or not installed properly on TV.
Please take out lamp inside TV and check, seems its broken as you heard loud pop.
Thanks.
Tv went out after loud pop and has clicking noise does not turn on
If you have a Sony DLP, then the loud pop you heard is your lamp.  The lamps last approx. 4K-6K viewing hours.  Read your manual for replacement part number to reorder and very simple to replace yourself.
3helpful
2answers
HEARD LOUD POP NOISE DLP TV DOES NOT WORK
Following up on my Feb 7 post. My new lamp arrived, and I replaced it and it works great. The old lamp had many shards of glass come out of it. It was tore up. I saved some money buy purchasing just the lamp and not the cartridge. It's a little bit more work to take apart, but saves money. Mitsubishi wanted $289 for the lamp replacement kit. I got a lamp for $114. TV is working just fine now!
My Toshiba 50HM66
i suggest checking the lamp. find you owners manual and go through the steps to "replace the lamp" if it is popped and you can see little pieces moving around inside than contact toshiba and they will send you a replacement with credit card numbers of course.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
