20 Most Recent
Zenith D52WLCD 52" Rear Projection HDTV-Ready Television Questions & Answers
Red color gone on tv?
is the red gone on all inputs? do you have the tv hooked up, to a sat box, cable box via component video (Red, blue, green connections)? if so check the red cable on both ends.
How do you reset light engine
If its possible you will need to locate a service manual to do it---a reset is available only on some sets and will not cure screen defects---only thing I have encountered is if it has one--it will correct communication issues between the engine and main chassis.
Rear projection tv trouble
Replace it. It is not worth the approx $600.00 to repair, new 46" LCD flat go for less then that. Check Costco and Best Buy have great prices. Also the color and clarity of the newer flats is far superior to any rear projection.
No picture no sound
The cost to repair (about $600) this problem will be close to the cost to replace it. I advise you to look for one of the new LCD flat screens, a 46 inch can be had for about $500 if you watch the sales.
I got a 52" zenith
No,the tv message said replace lamp wright?Yes,mean the tv projection lamp is the causes and the problems.The tv projection lamp life span have ended that why the tv it is not holding a stable tv projection lamp picture.All throught these causes,does the tv make alot of clicking noises too,when the tv projection lamp is it on for 30 sec.and shut it self off?Yes,than the board that call the Ballast board it is also dead too.This Ballast board only job are to ignite the tv projection lamp only.Tries websites like Partstore.com,Ebay.com to buy a new tv projection lamp and a new Ballast board too for the replament too,if this tv causes have alot of clicking noises,when the tv is trying to ignite the tv projection lamp.
The lamp went out in
Yes, the procedure you've entered, pressing the "?" key at the remote control at standby mode, follow by pressing 9,8,7,6 is correct to reset the lamp timer.
Another is by pressing and holding the "Menu" key at the remote control until the "OSD" (on screen display) menu disappears follow by pressing 9,8,7,6.
If the unit still keeps turning off, let me know which led light(Operation, Lamp, temperature) at the front panel lit solid/blink and its color to determine where the fault came from.
Jdvillanueva
How to reset the lamp
try this if you have the remote control, press the menu button continuously, The "OSD" menus will disappear then press the "9876" and press the "OK" button to enter "ADJ" mode you will see "Lamp Life Time" Then set the time to "00".
I have a blue streak on my screen that's about
it sounds like you have a light engine problem with your unit possibly a lcd plate issue if you have it under a extended warranty id call for service if not look for a light engine replacement
Someone from my townhouse put
usually that means the bulb for the projector is out there usually around 100 dollars! it could also mean the color board is out. so open it up look for the bulb if it looks blown then just buy the bulb and you got a nice tv if not junk it!
Red green and blue colors seperated
convergence settings buddy normal tv repair for under 100 dollars its a normal thing should be adjusted every 3 years but some tvs can last 10 years or even longer or sometimes less than 3 years its just your luck
