The labels for the printer won't line up to the print. I can physically move it to print correctly, but I end up wasting every other label. If I adjust it once, the next label to print out will be off by half a label, and it will stay that way. Thanks for your help.
Either your printer needs calibrated: Calibrate Zebra Desktop Printer
Or your label template size( in the software) does not match the label size. I recommend the calibration then looking at the software label templates.
SOURCE: ZEBRA TLP 2824 LABEL MAKER PROBLEMS
I've had this problem. I changed the margins and it solved it.
SOURCE: Zebra TLP 2824 Labels printing upside down.....How do we correct?
Change orientation in the printer driver.
Open printer & Faxes folder, Double click on printer driver icon,
Zdesigner driver, click on properties, click printing preferences, tick the box "rotate 180%" Click apply & ok.
If driver is Zebra TLP2824, same as above, but hit the + on "Paper output" and turn "rorate 180%" on, then click apply.
SOURCE: Zebra TLP 2824 Print Orientation
check on the driver, unther the advance tab, if some seting is tick.
if cant check the problem, install the driver again.
