Just watching a film and the screen suddenly went ultra bright have tried factory reset and that didn't work. Any other tips please!!
SOURCE: How to do a complete factory reset of a Sony Bravia KDL-32P3000
Just talked with Sony Support today.
It seems that Sony in Denmark had sent out new software updates (over DVB-T) but also some wrong TV's got updated as well. This caused my DVB-T tuner to not function anymore so I wanted to try a factory reset and it fixed my problem.
So I was instructed on how to do this. I have a Sony Bravia KDL-32P3000 (which should be similar to the U3000 and S3000 as well).
This is how to do a factory reset of your Sony Bravia KDL-32 P/U/S-3000 TV.
PLEASE BE VERY CAREFUL WITH THE SERVICE MENU, YOU CAN EASILY CAUSE YOUR TV TO MAL-FUNCTION!!!! IF YOU FOLLOW THIS GUIDE IT IS AT YOUR OWN RISK!!!
Set your TV in standy (use the green power butten on your remote), RED standby LED is ON on your TV.
Now press these buttons in this order on your remote (pointing to the TV).
i+
5
VOL UP (+)
GREEN POWER button
NOW BE CAREFUL! Dont press any keys just for the fun of it!!! IT MAY DESTROY YOUR TV.
You should now be in the service menu. It will show up as some green letter/numbers spread over the screen (mine are a bit hard to see/a bit faded). In the upper right corner you should have 2 letters TT (two t's).
Now carefully press key 0 and then key 8 on your remote (they should be shown on the screen after the two TT).
Now wait a little while (more than 10 seconds) and your TV should reset with factory settings, just as if you had just brought it home from the TV store.
Best wishes,
Mads
SOURCE: No sound in Sony Bravia
If the sound is not heard during tuner (channel) but is when using an AV input (DVD) then it is likely the Second Audio Program (SAP) has been engaged. Some SONYs simply have a button on the remote to toggle through choices, SAP is used primarily for second language transmission of audio. Either move to a PBS station or some other channel that specifies SAP programmimg or turn the choice (MTS in some SONY menus) back to "main" by either a remote button or in the audio menu.
Good luck.
SOURCE: sony bravia screen doesn't work but sound still
Ur Video converter board is dead,need a new one.
SOURCE: The picture on the screen
HI:
This is due to a faulty digital board, your board has failed replacement is the only option.
SOURCE: Sony Bravia - no picture,
First thing to try: unplug from the wall; count to ten; plug back in; try again
Second thing to try: unplug from the wall; count to 10,000 (or wait 10 minutes or so); plug back in; try again
#1 worked for me when it would power on with no video, no sound, just small green light + white logo
