Philips HTS-3565 Theater System Logo
Posted on May 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Want to make my philips DVD HTS 3265 a code free one. it is region 3 and I want to see DVD region 2
Anonymous
Level 2:
  • Expert 50 Answers
  • Posted on Jul 29, 2009
Anonymous
Expert
Level 2:
Answers
50
Questions
0
Helped
34600
Points
156
Open Tray
Place different zone DVD into player tray
Press 99990
Press Play
Enjoy
1helpful
2answers
I have a Philips HTS 3260/12 and I want to make it Region free. Does any one know how to do that?
Its not possible to change the region of the tv. On the back is a plate which shows you what region the tv supports. I suggest you find dvds and etc which the tv can play. Or you can try taking off the region code on the dvd file, but this is not strictly legal.
It may be possible that this DVD is not from the same region as my DVD player. PHILLIPS HTS 3265. But my question is how do I make out that my Video CD of violin brothers from ASHA AUDIO FALLS IN WHICH...
Hello Dhrubajyo,
[...] The VCD format has no region coding, so discs can be played on any compatible machine worldwide. Many VCD players can compensate for the differing frame rate and pixel count between NTSC and PAL/SECAM TV systems. [...]
http://en.wikipedia.org/wiki/Video_CD
You might have a problem with PAL/NTSC system here, but I assure you that it is not the matter of the region setting. Also - please, be careful when changing the region. Many players offer possibility to change it only several times. 5 times as the most often option. After 5 changes, the setting is locked.
2answers
I GOT YOUR HELP PREVIOUSLY. RECENTLY I AM HAVING FOLLOWING PROBLEMS WITH MY PHILLIPS HOME THEATRE MODEL-HTS-3265. **** I HAVE BOUGHT ONE VIDEO CD OF VIOLIN BROTHERS LIVE CONCERT FROM ASHA AUDIO BUT...
It's possible that this DVD is not from the same region as the DVD player.
For instance, a DVD from India (region 5) will not play in a DVD player from the US (region 1).
You may want to check into that and post a reply here.
1helpful
My philips dvd hts 3545 does not play the dvd says there is no disk. it could be a problem of region code. how can i unlock the region code to make all region code
hi,
you can make the player region free by the following setup.
1.TURN ON THE PLAYER
2.PRESS OPEN/CLOSE TO OPEN THE TRAY
3.WITH THE TRAY OPEN, PRESS STOP-7-3-4-4-6-6 in sequence
4.YOUR REGION AREA WILL BE DISPLAYED.
5.PRESS "0" TO UNLOCK ALL
6.PRESS "OK"
ok
2helpful
RECENTLY I HAVE BOUGHT A PHILIPS HOME THEATRE MODEL - HTS 3265 . ONE DAY I WANTED TO PLAY STAR WARS MOVIE DVD INTO IT. BUT NOT OPERATING.IT IS SHOWING REGION AND STOP PLAYING. PLEASE GUIDE ME FOR THIS...
HI,
ur dvd player has region lock . it will not play all the disk. check the DVD OF STAR WARS MOVIE which region it belongs. jus try the following not sure is it work or not
Open the tray. Press 99990 on the remote.
by doing this ur dvd player will become region free
then insert ur dvd and try.
for region 1 and region 2 code is 99991 ,99992 respectively.
feel free contact through fixya.
ok
Philips hts 6102 region codes
People seem to have said that there isn't a region hack for the HTS 6120, but I did mine yesterday by just following the standard Philips steps:
1) Turn on
2) Eject
3) Enter 99990 OK
4) Turn off (Standby)
Works fine now for region 1 and 2 (I don't have any DVDs from other regions).
5helpful
Multi region code for philips hts 3090 dvd player
With your set on and without disc in the tray:
1. Press PLAY from your remote control
2. Press the following button sequence: 1590 2379 390
3. Press PLAY again
This will release the region verification in your home theater (region free). However, some DVDs (multiregion in particular) will not play, since they require region detection from the player unit.
I've done this to my 3090 and been using it like this for 3 years.
4helpful
2answers
Unlock dvd player to play all dvd regions
I bought today a Philips HTS 8140 region 4 and i use this solution
1. Abrir a bandeja do aparelho / Open the tray
2. Aperte a tecla DISC / Press DISC buton
3. Digite o código 99990 / Insert 99990 code
4. Feche a bandeja / Close the tray
3helpful
2answers
Region code
I have a region Code For A Philips HTS-3544 which is 1 model Down. You can try it, it may work or it May Not.
Heres How:- power on the TV/DVD without any disk in the player.Press open/close eject.
Press Stop 7.3.4.4.6.6 ( on the Remote )
The menu code appears On The Screen.
Press 0 for region Free, or the region Code Required.
Power Off and then on Again, if the codes have worked, your dvd player is now region free.
If this works please rate as Fixya.
many thanks mike @ Compurepair.
3answers
Philips HTS 3164
Search for hts 3154 ....
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
