20 Most Recent Philips HTS-3565 Theater System Questions & Answers
2answers
Hi ,\r\nI am trying to play a DVD (Philip HTS 3565
lence is weak please chane the lence
3/27/2020 8:43:34 AM • Philips HTS-3565... • Answered on Mar 27, 2020
2answers
Doesn't play cd's or dvd's.
It's unable to read the source disc.Try using a comerically recorded disc.Try several different ones.Use a disc cleaner to clean the laser if all else fails
1/2/2020 12:02:25 PM • Philips HTS-3565... • Answered on Jan 02, 2020
2answers
Philips HTS 3565 system doesn't play MPEG-4(.mp4) formate.
HTS 3565 this model does not supports the MPEG4 video format, but you can play MPEG1, MPEG2, DivX 3.11, DivX 4.x, DivX 5.x, DivX 6.0, DivX Ultra, WMV all these formats.
11/13/2019 9:22:41 AM • Philips HTS-3565... • Answered on Nov 13, 2019
I have a vizio HDMI DTV telvision, and a sony
If you're using the HDMI cable with 5 wires, the red, blue and green wires are for video and the red and white wires are for audio. If your TV has a component IN RCA jacks, they connect there. If you're using the 3 wire cable, yellow is for video, and the red and white is for audio. You will NOT get HDMI pictures with this setup so you will have to go into the input selections and choose composite video input on the TV menu. Get a connection diagram from Visio's website or look in your owners manual if you have one. .Connect them to the corresponding inputs
7/28/2017 4:30:44 PM • Philips HTS-3565... • Answered on Jul 28, 2017
Unlock Philips HTS-3565
Hi
TURN ON THE PLAYER
PRESS OPEN/CLOSE TO OPEN THE TRAY
WITH THE TRAY OPEN, PRESS STOP-7-3-4-4-6-6
YOUR REGION AREA WILL BE DISPLAYED.
PRESS "0" TO UNLOCK ALL
PRESS "OK"
3/21/2013 7:33:20 PM • Philips HTS-3565... • Answered on Mar 21, 2013
How do i connect my pc to my phillips home theatre system through an hdmi cable
The best way is to connect your laptop to a spare HDMI input on your TV first, then use the AUX OUT from your TV to the AUX IN1 of the Phillips Home theatre system using a standard RCA cable. The only catch with this is that you will have stereo analog audio, NOT digital surround. However, by pressing the "SURROUND" button of your Phillips HTS remote you can switch the audio output to multi-channel surround, stereo or party mode. What is the model number of the TV you are using?
10/23/2012 4:27:24 AM • Philips HTS-3565... • Answered on Oct 23, 2012
Speaker wire problem
Yes you can splice the ends onto the existing wires, but first make sure the ends are labeled + or - and make sure you hook the other ends to the speakers the correct way. Before you cut the connectors off of the speaker wires mark one of each of the pairs of the wires with tape, on each side of where you cut it so you can match the wires back up. Are the pre-wired, wires labeled + and -? or red and black? Or one of each pair is a different color wire ie silver and copper? If they aren't labeled its going to be hard to get the correct polarity (+ and -) for each speaker. I hope this helps post back if you have any problems.
3/5/2012 4:49:38 PM • Philips HTS-3565... • Answered on Mar 05, 2012
I have Philips HTS3565 and
If you have necessary tools and test instruments, know safety precaution in basic troubleshooting try the steps below to solve your problem.
Assuming that the disc is good.
1.Clean the lens. - Sometimes because of dust and any fine foreign objects build-up, the optical lens can't read any disc. If you have a DVD Lens cleaner, play it to the unit. If this is not available you may manually clean the optical lens. Open the cover and gently clean the eye of the lens by smooth,clean,soft cotton buds. Be careful while doing this, just a gentle stroke only.
2.Check the ribbon - Check the ribbon connected to the lens from the main board for scratch, damage. Once it has an open line then of course the lens can't read the disc, this is because of the movement of the optical lens back-and-forth. Also try to erase the contact by pencil eraser. If you've done the steps above and the symptoms still there then the next step requires you a little knowledge in soldering technique and reading the ohmmeter.
3.Check the spindle motor - Check the spindle motor that spin the disc with an ohmmeter. You can test it using the ohmmeter (x1) even it is connected on the lens assembly.Good motor - reading should be fairly high and it will spin. Bad motor- reading will drop to low resistance and will not spin.
Click this link for more info.
LINK1
LINK2
Hint : Most of my repaired unit the above parts are commonly caused of the problem.
If you confirmed that you have a defective motor then replace it with a new one. Before replacing the new motor you have to check the clearance of the disc holder with the old one. The clearance should be the same as the old because if not the lens will not read the disc if it is too far or too close.
If the above steps didn't cure the problem, high chance that your optical lens was faulty.
If you can't do the job yourself, I would advice you to look for a professional to troubleshoot the symptom.
Also, check if your unit is under warranty period, avail it because the manufacturer will fix it for free. Don't attempt to open the cover(it will void the warranty).
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
9/7/2011 3:09:27 AM • Philips HTS-3565... • Answered on Sep 07, 2011
WHERE TO BUY REMOTE CONTROL
Here's the site for universal Philips remotes:
http://www.usa.philips.com/c/replacement-remotes/182940/cat/en/#filterState0=URC_REPLACEMENT_SU_US_CONSUMER%3Dtrue;tabState=0
You can choose different ones, and find the one you want. Make sure you click the Audio link under "Types of Device", so it can support your home theater. After you get the one you want, it allows you to find a store, or you can take the model number and look for it elsewhere.
7/6/2011 7:20:39 AM • Philips HTS-3565... • Answered on Jul 06, 2011
2answers
I GOT YOUR HELP PREVIOUSLY. RECENTLY I AM HAVING
It's possible that this DVD is not from the same region as the DVD player.
For instance, a DVD from India (region 5) will not play in a DVD player from the US (region 1).
You may want to check into that and post a reply here.
5/12/2011 7:35:25 AM • Philips HTS-3565... • Answered on May 12, 2011
Philips hts3565d keeps shutting off
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and
operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance
loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has
sufficient ventilation on all sides and that vent holes are not blocked by dust balls.
Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean
dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-
protection cycles in their lives so continuously resetting or cycling their power without
addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker
connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted.
If it does not come up the problem is internal and should be left to an experienced and
competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent
shutdown.
5/7/2011 11:32:57 AM • Philips HTS-3565... • Answered on May 07, 2011
I have hts3565 i want
Most universal remotes will have a code for this. take the make/model number with you and ask the sales clerk to check if the universal remote you are buying is compatible. They will either give you a return guarantee if it doesn't work or if the clerk really knows his customer service, he'll check for you before you buy it.
3/3/2011 1:05:04 PM • Philips HTS-3565... • Answered on Mar 03, 2011
It may be possible that this DVD is not from the
Hello Dhrubajyo,
[...] The VCD format has no region coding, so discs can be played on any compatible machine worldwide. Many VCD players can compensate for the differing frame rate and pixel count between NTSC and PAL/SECAM TV systems. [...]
http://en.wikipedia.org/wiki/Video_CD
You might have a problem with PAL/NTSC system here, but I assure you that it is not the matter of the region setting. Also - please, be careful when changing the region. Many players offer possibility to change it only several times. 5 times as the most often option. After 5 changes, the setting is locked.
3/1/2011 11:37:42 AM • Philips HTS-3565... • Answered on Mar 01, 2011
Philips HTS-3565 Theater System Logo
51 questions posted
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Audio Players & Recorders
Most Popular Question
recently bought
  • Audio Players & Recorders
