SOURCE: internal antenna
It sounds like the TV justs has a insufficient internal antenna system. If you can put an external antenna on this sytem do so just to test it.
SOURCE: NO SOUND ON NEW TV
What kind of Connection do you have coming from the Dish receiver to Your New Sony Bravia TV. This is very important information.
Best regards
CircuitCity
SOURCE: Digital not displaying
try to reset the unit.by unplugging it for sometime and then plug in.this will help.if the problem is minor.
SOURCE: My Sony KDL-46V2500 can't receive digital channel
signal booster, different tuners require different signal powers, by splitting the feed you've effectively halved the signal strength, a booster should bring it back,
SOURCE: I am using my KDL40V5500
Antenna input on tv, KDL-40V5500 does not have or provide any volts to LNA etc. Antenna input is to receive RF signal (digital or analog) by Ariel / antenna located in open air for better performance.
Dish preamp gets volts from dish receiver that is specifically designed for that.
Hope this will help.
Thanks.
Buckeye Cablesystem gave me an antenna (rabbit ears and hoop). Made connect on TV and powered it up. Did an auto search for digital channels; none found. What else would you like to know?
