Operation panel locking up
Good machine
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: konicaminolta bizhub pro c6500
its a 24Volt error. It usually means replacing the ADU drive board. no way to cheat or disable it/
SOURCE: Our KonicaMinolta Bizhub C280 Internal Error C2555
You didn't mention the size of the job size, but it sounds like a memory problem. If you have a service contract or it's still under warranty, contact your rep before you start opening things up.
The following is if you don't have a service contract. If the bizhub has been working with no problems in the past, try reseating or replacing the RAM. I've had to replace RAM that started causing problems on classroom computers. If you bought it refurbished (used) check to see the 2GB RAM that supposed to come with the bizhub hasn't been removed or replaced with smaller memory.
SOURCE: how do i set my KonicaMinolta bizhub C203 to copy
set the copier on black then go to utility/counter, user settings then set current settings
SOURCE: How to make nvram recovery
You'll need:
1- 1 compatible CompactFlash card (not all of them work, you'll need to try for yourself)
1- 1 CompactFlash card reader/writer
1- This tool
There should be a document enclosed with that tool explaining the process, it's fairly easy and quick. Notice that the procedure will solve some NVRAM related problems and also some network card related problems, but it will not erase your counters.
