I get great picture on my old tv with roku. I want the sound to come through the stereo system instead of the tv.
SOURCE: tv built-in dvd player wont play thru surround sound
use your t/v audio out with RCA cables to your reciever input like(vcr in, dvd in, dtv in)
SOURCE: no sound
I had the same problem on 3/21/09...I found it was the PS3 settings. I had to go into the visual settings (not sound) and change the linear sound to optic digital...but I also had to purchase a digital optical cable...plug everything into your tv instead of the receiver and then hook up the digital optical cable from your tv to the receiver. A it will work and b it is a better sound quality than that of the HDMI cable.
SOURCE: humming sound when watching tv,but not when watching dvd's
It wounds like you are getting interference from you tv to the receiver. You can try a few different things here.
1. Connect the tv output into another input on you receiver to see if it isnt the channel on the receiver.
2. Try a different set of cables between the tv and receiver. Faulty cables can give you problems.
3. Connect the cable from you tv to a different device. (another dvd vcr blue ray etc.) This will tell you if its the receivers or the tv.
SOURCE: i have wall mount tv connected to surround sound
Connect the wii cables to the TV/SAT IN on the receiver. Then connect a video cable of your choice from the receiver "MONITOR OUT" to the input of your choice on the TV.
SOURCE: How to get surround sound?
Hi, I would recommend using an optical cable from your Sky box to your surround system. The should look like this:
http://files.sandberg.it/products/images/lg/505-39_lg.jpg
