2001 Suzuki SV 650 Logo
Posted on May 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Clacking noise when starting out in 1st &2nd.
My 01 sv650 has a clack that repeats in first and second gear. Please someone help me understand what it might be.
  • cain4474 May 25, 2009
    You think? See it was doing that when I got it. I changed it, new filter, and put in Lucas 10W 40 for bikes. I was thinking it might be the Primary in the case. I know that I have to change the chain, and sprokets all at the same time, but I need to see if there is an adjustment for the case. Please hit me back, I would like any input possible.
    You see it was doing this when I got it. So I thought the same thing, then I went and changed the oil, and filter.(Used Lucas 10W 40 made for Bikes) Yet the problem is still around. I was wondering if it is the primary in the case?
    Please let me know what you think, I am open to all the advise that can be given. Again thank you for your input
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on May 25, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
265
Points
Oil in engine in tm racing 125cc
Anonymous
Level 3:
  • Master 408 Answers
  • Posted on May 29, 2009
Anonymous
Master
Level 3:
Answers
408
Questions
0
Helped
171563
Points
1030
Probably you need to have your gear box checked.The gears drum selector is a probable cause.
Why does my washing machine make a clacking noise during agitation...it goes clack, clack,
Hi
Clacking noise comes when either the agitator or the transmission or clutch assembly goes bad. To check which part# has gone bad you'll have to open the unit and first check the agitator. Please get back to me if you have any other questions.
Kevin
What will cause a Clacking/Clicking noise coming
It maybe a loose heatsheild on the manifold, converter, or underbody heatsheild.
I have a 2004 bmw 325i and it has a real ruff idle with a clacking noise it sounds like it has a vaccume leak and it will not click into gear. one thing i do no there is a bal valve cover
compression test engine to check top end for problems(clacking noises could mean low oil pressure or level or bad lifters etc). Have the engins smoke tested for any vacuum leaks
1helpful
2answers
Clacking noise at different engine idles on my Yamaha V Star
Lots of bikes make a clacking in the transmission , especially when cold at idle. Basically the engine accelerates and decelerates between each piston firing, and you hear the backlash in the gears slapping back and forth. Without hearing it I can't say for sure, but find someone else with a similar bike and see if it sounds the same.
Runs slow and makes a clacking noise I thing that it needs oiling after 20+ years of use. I have it detached from the stand, but cannot get it to open up to dust it out and oil the moving parts. Any...
It sounds like the brushes are worn out. The sound you hear could be the brush holders making contact with the commutator or it could be a broken brush. Also check gears for wear. Here is a website that has diagrams and parts. Hope this helps.
kellysappliance.net/mixer.aspx
Warm up noises
the only thing I can think of is the paper tray trying to lift up during warm up and there is a gear slipping but catches itself which is why you dont hear it again??
if you open the trays and close them does it do it??
Canon PC920 paper feed "clacking" & not working.
check the tray and make sure the guides are set correctly, clacking sound is usually because the tray is set for Legal and has Letter, the paper is towards the bac of the tray and the pick up assembly is making the noise,
otherwise the tray is either not going up (broken gear, )
"Clacking sound when receiving faxes"
a clacking noise is not good, what's the make and model of your machine.
Thank You,
Mikey
Top Suzuki Experts
Arnie Burke
Arnie Burke
Sean Wright
Sean Wright
Bob G
Are you a Suzuki Expert? Answer questions, earn points and help others
