My laptop is Toshiba Satellite P15-S420
It is two problems:
First: I tried to use canon scaner thru USB port, it worked great, but after usb stoped responding and I always get the message "Power surge on USB Hub"
Second: I was using my microphone, conected to laptop thrue external conection, and it stopped working. All playback is very good, but microphone doesn't work.
Thank you
Mine isn't working either, but it's because I tripped on the mic cable and probably knocked some stuff loose on the inside, I wonder how much it costs to get something like that fixed...
I have a Toshiba Satellite laptop and experience this problem with the mike stopping suddenly too. Your solution may not be as easy as mine was, but here goes ... Did you check the audio setup? Go to Audio Properties, and click Advanced so you can see the Microphone properties. Mine was muted and it wasn't me that muted it -- just seemed to happen suddenly and hopefully it's that easy for you!!!!
my mic is back, just rolled back driver. But USB is still down. Need Help.
I have the same problem with an external mike on my Toshiba Satellite. It worked for a while now it does not work. Changed mikes still does not work.
The same sing happened to me! I have a toshiba laptop and I was using the mike jack to talk using skype (i'm studying abroad in spain for the semester), and one day in the middle of a call it just stopped working! no other headsets work either. now i can't talk to my family :(
