Cannot turn on or off,or pair with phone
SOURCE: Cannot pair a7010 with Plantronics Voyager 520
The actual problem was Plantronics, I was not turning on pairing mode. I was confused with quick pair which starts not immediately after turning on, but you need to hold the button longer until led will start blinking blue and red.
SOURCE: how do i pair my jabra w/my phone. cant find
hold down the button till the light turns solid blue, then let the phone already in bluetooth mode find the jabra, it will ask for a password, enter 0000
SOURCE: my jabra headset won't pair with my phone--my
Assuming you're talking about the Jabra BT2050 headset press and hold the center (round) button for at least 10 seconds; light will stay solid entering the pairing mode. Follow instructions on your phone.
Testimonial: "This worked perfectly! Thanks!"
SOURCE: I purchased a new Iphone and my Jabra will not
To remove the list, press and hold the Answer/End button, Volume up button and FM button at the same time. A beep indicates the list was removed from the speakerphone memory. The next time
you power on, the speakerphone will go into pairing mode as the first time you powered your new Jabra CRUISER on.
Thank You
