20 Most Recent Jabra BT2050 Bluetooth Headset Questions & Answers
My Bluetooth speaker only plays when it is charging
Jabra BT2050... | Answered on Sep 23, 2016
why i cant listen music with my phone
Jabra BT2050... | Answered on Apr 10, 2015
Try pairing it again. Make sure Bluetooth is enabled on phone, turn the BT2050 on by pressing and holding the side power button. Then, press and hold the center (round) button for at least 10 seconds (light will stay solid and it is now on pairing mode). Follow instructions on your phone. Hope this helps.
Jabra BT2050... | Answered on Nov 29, 2013
Press and hold the center round on/off button for 10 seconds to put Jabra BT2050 into pairing mode. Type in pin "0000" when the BlackBerry 8520 detected the bluetooth headset, then the two should be paired. Hope this help.
Joseph
Jabra BT2050... | Answered on Jan 27, 2013
You can find the HFS001's Quick Start Guide here.
Hope it might suit your needs, somehow.
Anyway, please, let me know if you need further help.
Regards,
Carlos
Jabra BT2050... | Answered on Sep 03, 2012
Try to press and hold the center on/off button for 10 seconds, this will put the Jabra BT2050 into paring mode.
Assumptions made:
1) The BlackBerry is Bluetooth enabled.
2) The Jabra BT2050 is fully charged.
Hope this help.
Joseph
Jabra BT2050... | Answered on Jul 21, 2012
you need to intorduce again the jabra blutooth to your device. deleting jabra from the list make it forget the connection.
set your jabra to find mode by pressing the poer button for more than 5 seconds wait to blink, and find it using your device. it will again ask for a passcode and it will connect afterward.
Jabra BT2050... | Answered on Jun 07, 2012
    • 1 Unscrew the small screw in the center of the Jabra's body.
    • 2 Slide the body to the left until it slips off.
    • 3 Unclip the existing, old battery.
    • 4 Clip the replacement battery into place.
    • 5 Replace the cover and the screw that held it down with the screwdriver.
    • You must charge the jabra headset's battery and go through an easy setup process before use.
Jabra BT2050... | Answered on May 01, 2012
Hold round center button for 10 seconds, light will stay on and be in pairing mode.
Jabra BT2050... | Answered on Nov 02, 2011
Jabra BT2050 Bluetooth Headset  Logo
88 questions posted
Top Jabra Radio Communications Experts
Anthony Ward
Anthony Ward
Bobby G
Bobby G
Damen Wong
Damen Wong
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Jabra Radio Communications
Most Popular Question
dont know pass key number
  • Radio Communications
