Moultrie A-5 Game Camera Logo
Diana Cox Posted on Jan 03, 2014
Constant pictures taken
I have my camera set on hi and auto in hopes of taking pictures of wildlife, but when I pull the card and review, it is taking pictures of sun casting shadows, leaves falling and any kind of slight movement. What am I doing wrong?
A
Anonymous
If you are using a Micro sd card you will need a Sandisk sd card that says sdhc nothing higher the class 4 sd card which is the speed of the card. If still need help call Moultrie with equipment to troubleshoot the number to call 8006533334 option 1 and 1 live person
1helpful
Looking for manual for Maginon WK5AU wildlife camera as seen in pictures.
The maker doesn't know about a WK5 so you may have a Chinese Clone?
Maginon Download Center
Maginon https://downloads.maginon.de > home-english
Welcome to the Maginon Download Center. Are you looking for operating ... Wildlife Camera WK-4 HDW WiFi. 6.24 MB 39343 downloads. Show more · Surveillance ...
Aldi Maginon Wildlife Camera Review
Trusted Reviews https://www.trustedreviews.com > Reviews
Jul 26, 2013 - ALDI Maginon Wildlife Camera Review - Is the Aldi Wildlife Camera a great buy for wildlife photographers? Find out in our full review.
Rating: 3.5 · ‎ Review by TI Photography
Feb 22, 2024 • Cameras
Why is it that my pictures taken outside come out all white?
Hi. The camera could be faulty but it could also be because the camera settings have been changed so anything you take in good light is is 'over exposed'.
Try restoring all the options in the cameras menus to the original settings by using the review menu options of the camera e.g. on Samsung cameras this can be done as follows:-
[Setup2 Menu> 'Initialisation']
Then try taking some pictures with controls on 'Auto' at first.
Jan 16, 2011 • Cameras
1helpful
When i turn on my camera it says internal memory is full and I cannot take pictures
Hi there Gloria,
Your camera might be using the internal memory in saving those pictures.
You can press the Review button and press the left and right arrow to view the previous, next picture or video. You need to press the Delete button in each of them that you wan to delete. You might want to transfer your pictures and videos on the computer first before deleting them.
Then to set the memory card for the camera to save those images instead of the internal memory, just press Menu, then press either up or down button until you see Image Storage. Choose Auto; this option chooses the memory card if it is inserted on the camera.
Hope this helps.
2helpful
How do i switch off internal memory
How to switch the camera over to saving pictures directly onto the SD card.
    1. Menu
    2. Cam settings
    3. Chose AUTO or SD card option and Press OK
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
    After you have done so I would guess that you would like to transferre the pictures from your internal memory over to the SD card.:
Question :
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card? Answer :
Follow these steps:
  • On the camera, press Review and then Menu.
  • Select Image Storage.
  • Change to Internal Memory.
  • In the menu listing, scroll down to Copy, and select OK.
  • Select a single picture, or select All.
  • When you have finished copying pictures, reset the Image Storage location to your original setting.
  • 0helpful
    2answers
    I can only take one picture. If I take another,
    Try resetting the camera. Go into the setup menu and find "reset".
    Similar problems as other readers. camera turns on but no real time image on LCD screen. LCD contiues to show settings i.e. full auto mode etc. But I can view pictures already taken. Thanks
    The XTi and prior EOS models have not capability to see the live image to be shoot on the screen. Only the image after taken can see on the screen. Other images also using the view mode.
    If you can't review the images, eve if the display is turned off, just after they are taken, maybe the "Review time" is set to "off". Go to settings, 3th tab, Review time and set the desired setting.
    LCD is blank with no picture to review on my Canon EOS 10
    Make sure the auto review setting is on. Go to menu, and scroll down the list, you should find it there.
    1helpful
    Internal Memory is Full
    Go into review, and then menu. Go to image storage and then set "auto" or memory card. You may have it set to store your images in the internal memory.
    1helpful
    Auto is stuck on and I can't zoom in or out or review pictures - shutter button stuck also
    Being very careful, follow this pictorial disassembly (it's in Estonian, but just follow the pictures). Don't go any further than popping the top off the camera! Look for anything obviously broken off near the vicinity of the shutter button, or looking very different than what's in the pictorial. Keep in mind it's amazing what you can do with a little glue and scrap pieces of plastic:
    http://qman.fotokala.ee/Kaamerad/PowerShotA95/index.html
    Also, pay attention to the following post as there is some potential for electrical shock:
    http://camerarepair.blogspot.com/2007/11/important-warning-camera-flash.html
    Top Moultrie Video Cameras Experts
    ADMIN Andrew
    ADMIN Andrew
    Stan Ford
    Are you a Moultrie Video Camera Expert? Answer questions, earn points and help others
