SOURCE: Sony Bravia standby light flashing 6 times
there is a bad ground may on the cable check the voltage on the cable & set if on cable call the cable company. if tv call sony they may help with cost may be still under warranty
SOURCE: trouble with speakers (Samsung 2.1) to 52" sony bravia lcd
that is the simplest way. please rate, thanks and have a good day
Testimonial: "very fast, thanks for the help!"
SOURCE: My SOny Bravia 40 inch LCD TV has a vertical line
It could be 1 of 4 things:
1. One of the ribbon cables has worked itself loose (Simple Fix)
2. One of the assembly boards maybe faulty
3. The driver board which feeds the panel maybe faulty
4. The panel is faulty
The driver board in the UK costs approx £70 and approx £35-70 to fit it if this is the fault.
All other parts are between £80-160 and approx £35-70 to fit it if this is the fault.
The panel will cost approx 50-75% of what the TV was worth when you bought it - "Repair versus Replacement"
Thanks
SOURCE: Permanent Vertical Line on my Sony Bravia 46 inch LCD TV
What you're describing is usually the result of an improperly seated connector. With the power disconnected, open the tv and locate any connectors between the LCD screen and the driver circuit board. Unplug them, and reconnect it assuring it's properly and firmly seated. Be careful when handling these cables as they tend to be quite fragile... take your time.
SOURCE: hdmi port stopped working on sony bravia
I have a Sony Bravia model KDL-46s5100 that had the same problem. All HDMI ports stopped working. I don't know why this works but unplug the TV for about 30 sec, then plug it back in and hold down the power button on the tv for 10 seconds. Like I said I don't know why this works but it worked for me. Good luck.
