When you are on on screen menu setup, there should be 'reset to factory setting' to put it back to factory default setting. I am not sure which exact model you have, but you cann download user manuals here: http://www.retrevo.com/search?q=LG+Flatron+L1718S+
Hello you want to reset all parameters of your TV to Factory default, I assuems and posts this solution. 1. Press the "Adjust" button on the remote handset; press "Up" or "Down" button to select the "Reset" option. 2. Press "Enter " button and Use " >" or "<" button to select "Yes". 3. Press "Enter" button. All parameters will be set to its original Factory Defaults.
You can't just reset to default factory setting to use that phone. That phone need unlock code and you can get LG GW300 unlock code from your vendor provider with some charge up to $80 or you can buy lg unlock code from third party sites with more cheap price.
please refer to this picture: http://www.retrevo.com/r/375bh427/3/Connections+for+your+VCR#q=Zenith+VRB4215
Rather than use the method in the picture above you should use the audio L+R and video OUT on your VCR and connect these three to the color matching audio IN and video IN ports on your television. The colors are red, and white for audio and yellow for the video. If you do not own a cable like this simply pick one up at radio shack they will know exactly what you need. The pictured method will work also but the picture and sound quality will not be the best possible.
Remember you are sending data OUT from the VCR and IN to the TV
Go to the Settings Menu of your handset. There you will find an option to Reset your phone to factory default. "Reset Factory Settings or Restore Settings"
