20 Most Recent
LG Rumor Touch Questions & Answers
Hello, I got my LG
It is hoped you bought this new because there is an issue with the digitizer(the glass plate that sits on top of your lcd screen and recognizes when you touch the screen). I've worked on tablets and phones for several years now and, unless you bought it new and with a warranty then your next step is to take it to a reputable phone repair service and have them replace the digitizer. If you hold the phone up flat and you can see ANY kind of separation between the LCD and the digitizer, then it will NOT function properly.
Sometimes you have to replace both the digitizer and the lcd as they are one piece.
Hope this helps.
Reset button
please use this instruction.God bless you
Google "free cellular phone unlock codes" and
click on over to the top sites in the search results. Once there search for
your cellular phone model in the sites lineup. And follow their instructions to
unlock your cellular phone model.
· 2
Or simply surf to this site:
http://www.mobileunlock.co.uk/ Look through the listings for your cellular
phone number. And it is important to obtain your cellular phones IMEI number.
Look under the battery for the number.
· 3
Once the code is obtained enter it per instructions into
the cell phone and your GMS phone should be unlocked. Now, the cell phone can
be used with most U.S. carriers with compatible GMS phone service.
· 4
Also, there is a free software on the Internet available
that supplies unlock code for most Nokia cell phones. Find it at Downloads.com.
Link at end of article.
People can't hear me talk
Ohhhh....Its very bad news from you side please check the some primary solution.
- First Check your sound device connect correctly in specified port.
- Go to the control panel and select "Sound and Audio Device" select voice and "Test Hardware" and Press "Next" (Note: if any alert is showing about "Windows Firewall" please select "Unblock" option") after the click next,plug you Head Phone and Mic"
and speak if the wave effect same as above image then you device working perfect, if no, then change the device and try again.Tips: If you not solve the problem then try to uninstall you "Sound Driver" and Install again.Thanks to visit for Fixya...
