Sylvania LD320SSX LCD TV Logo
A
Anonymous Posted on Dec 30, 2013
Sylvania tv in test mode - Sylvania LD320SSX LCD TV
EEPROM hard reset what is the procedure to reset a eeprom either by lifting a pin or shorting across the pond
An EEPROM is an Electrically Eraseable Programmable ROM.
If the data is corrupt, re write the programme if you have the software to do it.
They rarely fail.
Check the 5/3.3volt supply.
My 32 inch sylvania model LC320SLX is flashing green,blue,red and more colors how do i get rid of it? It might be in color test mode
press up arrow then down arrow or left arrow then right should fix the problem iv had my tv do this twice and is how I fixed it but took me a while to find the fix both times so posting this here because this is the first result in my searches so hopefully if it happens to me again I can remind my self by helping everyone else
I have an old sylvania 6419 ctc 19 inch TV. I have a DVD player input in to the RCA inputs in the front of the TV but I do not have the remote. Is there any way to switch the TV to Video mode from the...
Tries tv manual channels buttons up or down few times some analog tv will let go into the video mode.Not,try website like Remotes.com to buy the tv original remote.
Game mode not working properly on sylvania tv
did you try to switch the tv modes Ex. my tv has av 1 av 2 comp 1 comp 2 does it have those modes
1helpful
I have DirectTV and a DirectTV remote RC64. I can
Here are all the codes I have
10171 10096 10187 10020 10381 10024 10030 11314 10186
here is how to set up without a code:
mode switch set to TV
PRESS & HOLD Mute and Select buttons at the same time UNTIL light blinks twice
enter 9911
keep pressing channel up until the channel changes on the tv
Maker sure to test the VOL button, if volume works
PUSH select key to set the code
THESE PROCEDURE CAN BE USED WHENEVER A REMOTE KEY IS NOT AVAILABLE.
CHANGE THE LAST NUMBER, 1 TO
2 for AUX1 (VCR and DVD)
3 for AUX2 (Audio Devices)
Xbox
I have the same problem with a 6420ff sylvania tv with a xbox 360. I plug the red white yellow into the front of the tv and it wont come on.
2answers
Sylvania TV stuck in Game mode remote no longer works
go up to your TV and go into the menu. Go to the channel selection and run the auto select for channels. This will take some time but the TV will end off the first channel found, the only thing is you cannot get back into video mode without the remote
Top Sylvania Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
