Windows7
Sharing my experience that my windows works properly from site www.vanskeys.com use a key to share you. Hope can help you.
SOURCE: I can't find out how to activate the "FN" keys. keyboard
1. Right Click on "My Computer" on the desktop.
2. Select Properties
3. Select Hardware
4. Select Hare ware Profiles
Find mouse in the list, double click...
Click Disable
Click OK
You are done!
SOURCE: HOW DO I ACTIVATE AND
Look for "Num Lock" key, it would be located on top left of set of number keys on right side of keyboard, press it to activate numbers keys set and press again to deactivate. Many keyboards have small light to show activation of that function.
Let me know if you have additional question.
Thanks.
SOURCE: In my keyboard there are
Hi jaywaxxy, you can access the blue keys by pressing and holding the fn key found at the bottom left part of your keyboard. Hope this works :)
Examine your keyboard to ensure your "Number Lock" key is not activated.
This activation is indicated by the key being lit up.
If the key is activated, press it to deactivate the lock.
The number lock key will deactivate an entire segment of your keyboard
Start, click Run, and type regedit to open the Windows registry editor.
In the registry, open the below folders.
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
Within the keyboard folder, you should have a string value named "InitialKeyboardIndicators" with a value of 0, 1, or 2. Below is the explanation of each of these values.
0 = Num Lock is turned OFF after the logon.
1 = Disable Num Lock.
2 = Numlock is turned ON after the logon.
hope this helps
Press the Start key + R.
type osk in that box and hit enter
On this keyboard, try toggling numlock scrolllock and capslock a few times.
Also, try this too: Fn+Numlk or depending of the model, press the button or Fn + Shift +Numlk
hope this helps
Try this. Press the Start key + R. type osk in that box and hit enter On this keyboard, try toggling numlock scrolllock and capslock a few times Examine your keyboard to ensure your "Number Lock" key is not activated. This activation is indicated by the key being lit up. If the key is activated, press it to deactivate the lock. The number lock key will deactivate an entire segment of your keyboard Start, click Run, and type regedit to open the Windows registry editor. In the registry, open the below folders. Within the keyboard folder, you should have a string value named "InitialKeyboardIndicators" with a value of 0, 1, or 2. Below is the explanation of each of these values. hope this helps
or
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
