General Electric Stove/Oven/Range Chrome Timer Knob Set - WB3X459 Logo
Posted on May 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to set clock on GE range
My GE Range model # is GRML3500ZWW-3 and we cannot find this anywhere online, it is used and we just got it today, we are unable to figure out how to set the clock...please help
  • Anonymous Feb 29, 2016
    My GE Range does not have a Clock Button. I have to press "9 + 0" for 3 secs to bring up the Clock to change the time. After putting in the correct time, I have to press "Start".
  • Anonymous Mar 12, 2017
    pressing ours isn't doing anything
Anonymous
Level 2:
Sniper:
  • Expert 95 Answers
  • Posted on May 19, 2009
Anonymous
Expert
Level 2:
Sniper:
Answers
95
Questions
Helped
80389
Points
376
Press and hold the timer key for 5-10 seconds see if it flash;s if so use the arrows for hour and min, comment back with all the setting/buttons it has other than temp for individual ranges :)
Hope this helps ya!
  • 2 more comments
  • tholepin Mar 21, 2011
    I have a GE range and I've been trying to set the clock too, but nothing seems to work. It has 3 buttons (a timer button, one with a picture of a pot with steam, and one with a picture of a pot), as well as a knob. When I press any of the buttons it goes to a timer, no matter how long I hold it down. The timers are of various types, how many minutes, what time relative to the current time, etc, but nothing I do seems to be able to affect the clock. I'm a professional programmer, but I'm stumped when it comes to setting this clock! Any ideas?
  • Michael Moriarty
    Michael Moriarty Mar 15, 2021
    This worked for me! Thanks!
  • Gillian Geddes
    Gillian Geddes Dec 11, 2023
    You’re a genius!
  • Jana Dougan
    Jana Dougan Feb 23, 2024
    Worked like a charm! Thank you!
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 21, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
29341
Points
I think I have a diff model than yours but I was attempting complete what I thought was a easy task. Press the clock button an pres the plus or minus arrows to set the time. So I pressed clock and pressed the arrows keys well that only changes the minutes, ok, so solution would be to press the clock again to go to the hour number. Wrong pressing again turns the clock off. This is so stupid. Tried couple othe things then decide to google. Nothing. So I said let's press theminute up button to 60 to see what happens. I presed to 50 and the hour changed. Ok. Good not feeling so stupid anymore. I held the key down until I reached the desired hour and then selected the minutes. Model 183d8077g143
Randyqb
Level 1:
New Friend:
  • Posted on Jun 24, 2016
Randyqb
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
29341
Points
7
After messing around I found that holding the clock button and using the arrows at the same time worked for me
Ge profile gas range, no clock pad...how do i set clock. It says hold 3 seconds. What do i hold?
You didn't give a model number, but try the following:
For an electronic clock:
Touch the Clock pad. Touch the number pad. Touch the start pad until the time of day shows in the display. (Taken from the GE website)
Reset clock on over the range microwave
Go to this link....you can download the users manual. The procedures for setting the clock are on page 22 of 68.
JVM1950SR1SS GE MICROWAVE Manual
Ge xl44 squealing
Replace clock. Most likely defective
Purchased GE Profile dual fuel range 6 months ago. Clock has always run fast and today the entire touchpad control went dead. The oven light works as does the gas burners. I am not sure if I inadvertly...
Unplug the unit and wait 2 FULL MINUTES before plugging it back in. That will reset the circuit board and you should be good to go. If it doesn't work, my bad!!!!!!
-AGK
During a day of heavy cooking my electonics have gone crazy... at the drop of a hat "she" will decide to ask for an oven cleaning...and will start to beep and flash f7. suggestions?
Hi katheyquilts,
F7 on most all GE ranges indicates either a stuck keypad function or a faulty clock. The only thing you can do as a do-it-yourselfer is this, push the clear/cancel or off button (depending on what model you have it will be labeled one of those)
If that doesn`t remedy the F7, you`d be best served calling in a pro appliance technician. Unless you feel capable of pulling off the panel at the rear of the range and locating the "ribbon connector" which connect`s the touch pad to the timer/clock, carefully, unplugging that connector and then re-connecting it. If you attempt this, **Shut off the 40amp breaker to the range first**
This remedy is a generalization and your range may not even have a type of "erc" (clock) which uses a ribbon connector from the touch pad to the timer. If you could provide a model number I could perhap`s be more specific if I`m able to locate your model number in a data-base.
Hope that help`s move you forward or solve the problem. I`ll look for your reply regarding a model number...unless the other suggestion`s work of course. ;)
Thank you for visiting "fixya" today and good luck.
macmarkus :)
How to use stove timer for auto oven?
See if this helps. Page 26 shows a digital clock. Even if the buttons and knobs are different on yours the procedure may be the same.
http://genet.geappliances.com/DocSearch/pdf/49-4751.PDF
3helpful
2answers
GE XL44 Gas Range JGBC15GER2. Can't see clock on stove; very dim. Do I need to replace the clock/timer?
yes it is called a electronic oven control go to ap wagner.com and enter the model number and you can get priceing
GE oven clock losing time.
I think I got this.... my oven clock does run slow for months then perfect for months, then slow again. I believe a repair would be a waste of money since there is nothing wrong with the clock. The problem is with the supplier of electricity. The oven uses 220 so may be related to the coverting 220 to 110 v. The clock is counting cycles in the electricity supplied to your home and that varies all the time.
1helpful
GE XL44 Gas Range Clock Display frozen with only an "8"
This happened to me.  I just unplugged it and plugged it back in.  It worked!
Top General Electric Hardware & Accessories Experts
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a General Electric Hardware and Accessory Expert? Answer questions, earn points and help others
