To wire into car loom for trailer, found the connection need to know what colour wire do what function for the 7 pin trailer plug
SOURCE: 1996 Dodge Ram Factory Trailer Wiring Schematic
all you need is a cheap continuity tester, any one to help tap on the brakes..7pin is just like the 4 pin w/extra power wire for acc.lites,electric brakes.when you buy the 7pin rec.,comes w/wiring schematic standard to all trailer rec.- you can do it..kev-mn.
SOURCE: looking for color code (diagram) - 7 wire trailer harness/wiring
If you haven't purchased the plugs yet. The wire color codes should be included in the package.
SOURCE: Wiring diagram
If you are going from a 4 pin on your trailer to the 7 pin on the truck. You need to go to parts store or a department store (ex Wal Mart) and look in trailer section and find the adapter. Thats what I did. Also Remember if your lights don't work on trailer, check the plug to make sure its tight or check the fuse under your drivers side rear seat for that fuse box.
SOURCE: I need a wiring diagram for a 7 pin trailer board plug
Here's one
CAV
CIRCUIT
FUNCTION
Z13 12BK
GROUND
B40 12LB
TRAILER ELECTRIC BRAKE OUTPUT
L76 12BK/OR
TAIL LIGHT (Trailer Tow Relay in PDC)
A6 12RD/TN*
FUSED B(+) (40A, Always Hot, F8 in PDC)
5
L63 16DG/RD
LEFT REAR TURN SIGNAL
TRAILER TOW
6
L62 16BR/PK
RIGHT REAR TURN SIGNAL
CONNECTOR
7
L1 16VT/BK
BACK-UP LAMP
FIGURE 1: 7-Terminal Trailer Tow Connector
SOURCE: Tow bar trailer socket wiring connection point to car wiring?
The connectors for towing wire harnesses on foresters are generally on the passenger side, below the rear taillight inside the cargo space. some require pulling up the foam block that is between the spare tire compartment and the taillight. Check where you replace the tailights from inside the car, if there isn't a matching connector hanging out there, check around the spare tire compartment, see if you can remove the carpeted foam block next to the compartment and find the plug under there.
