Was working fine, then it powered off suddenly. All lights are completely off and it won't turn back on. I've checked the power source, everything is working fine.
How long has it been running, projectors ALWAYS turn off when the overheat remove anything covering the cooling vents and it may have dust inside which will compound the problem.
Solution wait for 5-10 minutes.
If it is 13 years old, it has most likely reached its end of life--whatever the cause, something has malfunctioned. However, a service technician would probably be able to advise.
probaly lost fuel pressure, from fuel pump going out, or relay went out. Need more info such as, did engine stop running completly, or did it start back up etc. post back please.
This tablet does t reset with the power button unlike other Android devices. When you hold down the on/off switch, it only drains the battery. If you see the color indicator still charging, allow a full charge.Then, only stay put and pulse the button for a moment quick and let it rest few seconds to try again and again. Only when u see a light coming out of the screen, and I recommend you do this with the power cord on, you hold the power switch down until the rebooting is iniciated. Let go til it is finish and see where the problem is. More likely, like mine, the Settings stop working and needs tune up for the CPU. Never leave an application running when closing your system. With or without internet connection.
You may have already done this, but remember many laptops require that you remove the battery for about 30 sec. as well as disconnect the AC power to reset them. Always try this when everything appears completely dead.
Could be almost anything ! Do the usual simple checks - fuse in the mains plug (should be 3A), have you got another piece of equipment (radio etc.) that uses the same 2-pin plug for power - use it to check that the mains cable is OK. If the mains cable is OK, it maight be the switch on the power supply module or the power supply module itself ('L'-print), but could be more ... check if the sewing light or display backlight is coming on, but if completely dead, your only solution is to get it checked-out by a Bernina service agent.
This may be a longshot, but many electronic devices like TVs, dryers with electronic computerized controls, entertainment systems like the Wii, and other devices sometimes get "confused" and won't turn on, turn off, or otherwise work properly, perhaps due to a small power surge in your AC line.
I've found that one of the first things to try when it appears to be a failure of the electronics and not a mechanical issue is to unplug the device at the wall (to make sure that any power adapter is also unplugged) and wait about 10 minutes for any residual electric charge to dissipate. Then plug the device back in and give it a try. This has worked with a television, a Wii console, an electric clothes dryer, and some other devices that I thought had died for good. This may explain why sometimes a device is taken to a repair shop and it works fine.
There are, of course, other reasons that the unit won't turn on, but I would try this first before looking for other reasons for the problem.
