20 Most Recent Epson PowerLite 61P Multimedia Projector Questions & Answers
Won't turn on
How long has it been running, projectors ALWAYS turn off when the overheat remove anything covering the cooling vents and it may have dust inside which will compound the problem. Solution wait for 5-10 minutes.
12/26/2013 8:01:58 PM • Epson PowerLite... • Answered on Dec 26, 2013
Projection size won't enlarge
go far from the screen and try.
3/14/2008 6:57:53 PM • Epson PowerLite... • Answered on Mar 14, 2008
2answers
Epson lq-690II printer reflects the paper when printing
Troubleshooting Paper Reversal in Printers: *Confirm that options related to paper handling are set correctly by checking for specific buttons or switches that relate to paper handling or reversing. *Ensure that paper is loaded properly to avoid feeding problems. *Remove any dust, particles, or paper remnants from the rollers, as they can impede paper flow. *If other measures fail, reset the printer to its initial settings to resolve potential software glitches.
4/2/2024 6:40:17 PM • Epson Office... • Answered on Apr 02, 2024
Old but New in box epson pictureMate photo lab has paper jam error but never had paper in it .what can i do ?
If you take is apart you may find jammed gears or dry lubricant causing a 'paper jam', due to its age and storage.
2/29/2024 9:14:17 AM • Epson Office... • Answered on Feb 29, 2024
EPSON 15140 error 034019
Try a hard reset of the printer. Oddly, the 034019 is not an error code, I have reason to think. It is a contact number, I believe.
2/25/2024 3:05:22 AM • Epson Office... • Answered on Feb 25, 2024
6answers
Reset my Epson printer L382
Follow the steps given below to reset Epson L382 printer. Step 1: Turn the printer off. Step 2: Press and hold the reset button which is on the back of the printer using a paper clip or tip of a pen. Step 3: Turn on the printer by holding the Power & reset button and continue to hold both the buttons. Step 4: Wait for 5 seconds and a warning sheet will print. Release the reset button. Step 5: After 5 seconds, another sheet will print which will show the IP address of the printer. hold the reset button which is on the back of the printer using a paper clip or tip of a pen. WHERE IS RESET BUTON? I CANT FIND IT.
1/30/2024 1:36:34 PM • Epson Office... • Answered on Jan 30, 2024
Head teperaturer error 43H code
I have the code on I dtf printer 43 H : Head Teperaturer
1/19/2024 4:27:06 PM • Epson Office... • Answered on Jan 19, 2024
I have Epson printer workforce pro c5790 shows error 000101, what is the solution for it ?
The error code 000101 on an Epson Workforce Pro C5790 printer typically indicates a problem with the print head. Here are some steps you can try to troubleshoot and fix the issue:
  1. Perform a print head cleaning: From the printer's control panel, navigate to the Maintenance menu and select the option to perform a print head cleaning. This will help to clear any clogged nozzles or debris that may be causing the error.
  2. Perform a print head alignment: From the printer's control panel, navigate to the Maintenance menu and select the option to perform a print head alignment. This will help to ensure that the print head is properly aligned and is able to print correctly.
  3. Check for any physical obstructions or debris in the print head area, if you find any, remove it carefully.
  4. If the error persists after trying the above steps, you may need to replace the print head.
  5. If none of the above steps work, it is possible that the printer has a more serious problem that requires professional service.
I recommend you to check the user manual or contact Epson technical support for further assistance and specific troubleshooting steps for your printer.
1/17/2024 4:18:52 AM • Epson Office... • Answered on Jan 17, 2024
2answers
How can I fix my Epson Artisan 1430. It has the paper and ink lights alternating and the power light is on!
https://files.support.epson.com/pdf/art1430/art1430ug.pdf look under troubleshooting - could be a bit if paper stuck inside and hard to see
12/31/2023 2:54:56 PM • Epson Office... • Answered on Dec 31, 2023
Hi, EPSON C1900 Jam C problem without paper feed.
11/17/2023 7:37:31 PM • Epson Office... • Answered on Nov 17, 2023
Epson sticky solenoids : input /suggestion
11/17/2023 7:25:56 PM • Epson Office... • Answered on Nov 17, 2023
Epson Stylus Pro 4880. Service Reqest error code 0001001B
Epson Stylus Pro 4800 - Error Code: 0001001B
Printcopy.info https://printcopy.info > brand=Epson > code=0001001B Code: 0001001B · Description: Head driver (TG) temperature error · Causes: • Print Heat increase due to empty jetting of ink • Faulty contact of Head FFC, broken ...
Service Req 0001001B?
T-Shirt Forums https://www.t-shirtforums.com > ... > TexJet Jul 23, 2013 - The 1001B error indicates a temperature problem in the print head. In most of these cases, it means that after a print head and/or damper unit ... Service Req 0001001B, Help! May 19, 2012 Error Code 00010028? Jul 14, 2013 Service Required 0001001D Oct 30, 2012 Error Message 00010035 Sep 30, 2020 More results from www.t-shirtforums.com
11/9/2023 6:13:42 PM • Epson Office... • Answered on Nov 09, 2023
Brand new Epson ET8500 and the lid will not close. Suggestions please?
See user manual, go to Transporting your device. There are illustrated instructions. It will help you. ET-8500/ET-8550 User's Guide (epson.com)
11/8/2023 11:31:22 AM • Epson Office... • Answered on Nov 08, 2023
My Epson Artisan 725 continues to flash printer arror
According to the Epson US website, if your printer is displaying an error code or message on the control panel, you can search for 'Error code' on your product's FAQs tab. Examples include 'Paper jam,' 'Replace maintenance box,' and 'Printer is Offline.'. Epson Printer Problems and Troubleshooting ' Epson US
10/30/2023 4:33:11 PM • Epson Office... • Answered on Oct 30, 2023
LCD strip for Epson EHTW650 not working
1. Epson Service Center: Contact Epson directly and inquire about the availability of the red LCD strip as a spare part. They may be able to assist you with purchasing it directly from them or guide you to an authorized dealer.
2. Authorized Epson Retailers: Check with authorized Epson retailers or resellers in your area. They may have access to spare parts or be able to order the red LCD strip for you.
3. Online Marketplaces: Explore online marketplaces such as eBay or Amazon to search for the specific red LCD strip compatible with your Epson EHTW650 projector. Ensure that you find a reputable seller and verify that the part is genuine and compatible.
4. Epson Parts Distributors: There are third-party parts distributors that specialize in selling spare parts for various electronic devices. Search for Epson projector parts distributors online, and reach out to inquire about the availability of the red LCD strip for your specific model.
When purchasing spare parts, it is important to ensure that you are getting the correct and genuine part that is compatible with your Epson EHTW650 projector. Double-check the part number and specifications with the seller or the Epson service center to ensure compatibility.
10/28/2023 2:12:17 PM • Epson Office... • Answered on Oct 28, 2023
Epson PowerLite 61P Multimedia Projector Logo
Popular Tags
5 questions posted
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Epson Office Equipment & Supplies
Most Popular Question
turn
  • Office Equipment & Supplies
