I plug my mpk mini into usb working usb port and computer does not recognize it lights flash out. New strait out of the box
SOURCE: i brought a akai mpk
Your machines are different and likely have different interface chipsets. Some newer machines have more built in plug-n-play than others. There is so much incompatibility that it is a wonder that any of the stuff works together. You need to install the needed driver... NOTE: there is a lot of incompatibility between OS versions... so if for instance you are using XP on one machine and Vista or Windows 7 on the other there are a LOT of incompatibilities. ALWAYS check the requirements for the computer with the specs of the device to be connected. MOST of the problems are due to OS variations. Check for driver updates on the Sony site
