20 Most Recent Akai Ewi4000s Electronic Wind Instrument Questions & Answers
1 Un screw all the screw on black panel, but must remember where each on goes, but Be careful not the two screws in side mouth pice which holding the pitch bend unit. 2. open the battery cover remove all the battery 3. Remove the 1/4 earphone nut, and all screws on the silver metal case. (Under the black plastic ), you don't need to remove any screws from the "key" side 4. Use something to pull the battery Cartridge sideway out from Main attachments, but not all the way out from the ewi case, because you can't, the plastic case structure will be in the way, 5. Use some flat pice metal like dinning knife insert in to between black and sliver metal to separate the two parts, start from the mouth pice end, once you open wide enough the battery cartridge can be remove from the case out. Now you can open the Ewi 4000s and see the two HX nuts that holds the strap mount, put some Nail polish on it before you tie them up.....Warning.. You must pull the battery cartage sideway out from its electric plugging mount before you are trying to separate the plastic and silver housing otherwise you will damage the circuit board. That was What I did to mine. Good luck and may God provide you wisdom for this.
Akai Ewi4000s... | Answered on Apr 26, 2018
Hi, try to find how to reset it or go to default mode,find out in the users manual.Hope it will solve your problem,
Akai Ewi4000s... | Answered on Oct 17, 2017
My EWI 4000s started to play by its self making a loud low note and then it stop and now it won't play at all. I Reset to Factory Preset but that didn't help. What do I need to do to get it to play again?
Akai Ewi4000s... | Answered on Sep 02, 2014
hi, i have a YAMAHA WX5, and want to know if it's to use a Vocoder?
Mike Phillips is the same, or if it only works with the EWI 4000s?
and as a connection is made?
thank you!
Akai Ewi4000s... | Answered on Jul 28, 2013
You may need to do a factory reset. It sounds linke a transpose setting has been invoked. Read your manual under the word "transpose". A factory reset, if required, usually involves holding one or more buttons or keys down while turning on power and holding them until the reset is acknowledged.
Akai Ewi4000s... | Answered on Jul 21, 2012
Akai Ewi4000s Electronic Wind Instrument Logo
64 questions posted
Top Akai Music Experts
Michial Gueffroy
Cameron Lewis
Cameron Lewis
Level 1 Expert
Becketts Music Ltd
Becketts Music Ltd
Are you an Akai Music Expert? Answer questions, earn points and help others
View Most Popular
Akai Music
  • Akai Music
Most Popular Question
akai ewi 4000s neck strap mount
  • Music
