Baby Gear Logo
C
Chris Lockman Posted on Dec 24, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Handle does not catch - Cameleon Bugaboo Baby Gear
Stephen Faulkner
Level 2:
Guru:
  • Expert 541 Answers
  • Posted on Jan 13, 2014
Stephen Faulkner
Expert
Level 2:
Guru:
Answers
541
Questions
Helped
237784
Points
983
V:* {behavior:url(#default#VML);} o:* {behavior:url(#default#VML);} w:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} A lot of locking problems are just poor lubrication so before you start opening parts, get a can of Silicon Spray (Bugaboo use to include a can in their maintenance kit). Any hardware or Gas Station will sell it. Don\'t use Oil based lubricants like WD40 the main reason being they stain fabrics and attract dirt. Remove the seat unit and lay the stroller on its side faulty hub down. Now look on the inside edge of your handle where it joins the plastic hub, you\'ll see two slots in the plastic hub and a wire rod in the lower slot. Spray into this slot so lubricant flows down inside the hub. Now wipe off excess with a paper towel and work the release button a few times. If you are lucky your handle now works. No luck? Then we have to see if the fault is in the hub or the release button. Press or pull the release button while watching the wire rod in the lower slot. It should move 6 to 8 mm. If there is a resistance to this, the hub is at fault. If the rod seems to move freely but the hubs remained locked try pulling the rod a bit further up with a small pair of pliers. If this releases the hub you have a release button fault. If the hub is still locked the fault is in the hub. Bugaboo handle issues can be caused by faults in either the release buttons or the hubs and the first job is to try and diagnose the part causing the fault. I\'ll describe how the locks work then go into more detail on each part. Two aluminum lock pins sit in channels of the inner hub and extend into pockets in the outer hub, locking the hub. These lock pins are retracted by the rotation of a plastic disk connected to the ends of the lock pins by two small plastic pins on the disk. A wire rod clips into the disk and runs up the handle to the release buttons. There are two versions of the release button. The older pull up knob type (Gen 1) and the newer rocker button type (Gen 2). Both versions pull up the wire rod, the Gen 1 rod clips into a black plastic block in the handle and the release knob screws in to it. The (Gen 2) has a rocker button that moves the rod up via a white plastic block clamped to the wire rod by two small Alan/hex screws. A compression spring sits above the plastic blocks of both versions held by the caps where the upper handle comes out. The spring keeps the downward locked position until upward moment from the release buttons unlocks it. Check that the cap is fixed down. If not that is most likely your problem. If you are missing a spring your local hardware shop can find something similar. It does not have to be exact but if using a different spring change both sides so both sides have the same \'feel\'. handle does not catch - clip_image002.jpg . Release Button Repair The old pull up release button (Gen 1) rarely fails which is fortunate, as you have to drill out the rivets in the handle holding the hubs to pull it out. The (Gen2) is easier to get to which is fortunate as it does fail and can be your problem the most common fault being the two screws holding the rod coming loose. From the brake (left) side remove the two Phillips screws and the inner half of the assembly will come off rocker button attached. The brake lever, inner brake release button and spring will be loose so carefully place aside in a small container till ready to reassemble. The right side has no screws it just clips together. Use a small flat blade screwdriver to pop the joints on the front and back edges, the inner plate with rocker button attached will come free. There is a metal plate sitting over the hole the rod is in. Take time to remember how it fits in the hole and the angle you take it out. This will make putting it back much easier. The wire rod runs though a white plastic block clamped by an inner metal block with two inset hex screws. The hex key is 0.05 inches or a 99-20 if you have Xcelite hex drivers. Adjust the rod by pulling a few mm though the block and relocking. Don\'t take up any more then required to unlock the hub other wise the locking rods won\'t fully engage in the hubs when locked. Hub Repair 1/. Remove the capped star lock washer. Use a small painters knife to protect the plastic first hammer the knife in between the dome and the plastic, then hammer a large flat blade screwdriver in between the dome and the knife. Work from one side than the other to "walk" the dome up and off the shaft. There may be a second plain star washer under the Dome you can use a small screwdriver to "walk" that up and off too.
Note it is best to open and repair one side at a time, so your moving and flexing one side of the handle does not dislodge parts in the other side. The hubs and disks are mirrors of each other and not interchangeable the locking rods are interchangeable. Bugaboo designate the side with the brake lever as left, the Bugaboo parts will have an "L" after their serial numbers. 2/. Check the hubs for wear. If too badly worn or damaged you will have too much movement in the locked position. You can fix this by cutting a 20 mm section of a 3 to 4 mm house nail drilling a hole the same as the nail in the damage hub wall next to the pin then epoxy it in. clip_image014.jpg3/. There are three parts in the hub, a plastic disk and two aluminum-locking rods. The disk has two plastic pins that move the locking rods in and out of cannels in the inner hub. Why Bugaboo use plastic for this vital component is a mystery to me? If you need to repair the disk you can try drilling out the pin stumps and using a cut down 4 mm cap bolt. clip_image022.jpgOr (my preferred choice) have a new disk fabricated that will last a lifetime. The locking rods if broken can only be replaced, either by ones salvaged from another frame or new laser cut or 3D printed copies. I prefer the copies as they have been cut / printed from stainless steel. I sell both metal $30.00 and plastic $10.00 disks, and the stainless steel locking rods $16.00 each direct from <shapeways.com/shops/bugabooparts> Shipping is only $6.00 to USA $9.50 EU and $20.00 for the rest of us 8-( If you are in Australia or New Zealand contact me directly [email protected] for better shipping direct from New Zealand 3/. Reassemble handle locking hub and check operation. If wire rods seem to be in the incorrect position try pulling the handle up to it\'s full extension, if that does not work loosen the top plastic fittings where the handle extends from by removing the small self-tapping screws (note I\'m now finding some frames now have pop rivets, drill them out and replace with self tappers) and wiggle things into alignment. (I use a small amount of the silicon grease used for taps to give a smooth action) If all is working well fit the new capped star lock on the hub shaft and tap home. To protect the dome finish I use a large socket from my socket set and an old rubber washer from a toilet cistern. Repeat operation on the other side if necessary. Once repaired, I can\'t empha enough, the need to keep Bugaboo hubs well lubricated. They have to endure incredible forces from the handle. To give you some idea, a crow bar of the same length can pull six-inch nails out of hard wood! If you have further questions or require other parts you can contact me
The left rear door is open on my 2010 Ford Escape, but the child safety lock is in the locked position and the door will not close.The key does not turn the child safety lock to the open position.
I am not familiar with the model but door mechanisms tend to be similar between makes and models and a thought occurs...
When a door is closed the catch is pushed over the striker and when it is fully home the catch latches and holds the door closed. That is what happens when everything is in good condition and correctly adjusted though sometimes some designs of catch can be defeated when the door is allowed to swing with insufficient force to close it, resulting in the catch latching in the closed position while the door is open and consequently the door won't close until the catch is released.
Many but not all door catches will reset when the door handle is operated - some must be reset using a rod or screwdriver mimicking the door striker while operating the door handle. The child safety lock generally immobilises the internal handle but leaves the outside handle and the catch/latch to operate normally.
If the door does not operate predictably as per the owner's handbook, you should assume there is an internal fault - mostly caused by maladjustment and/or a lack of lubrication.
REPLACE CLONE CATCH ON HANDLE
depends on machine model some you remove with a screw driver and pry it free from one side of the catch and remove the little spring and some you need to pull the cyclone unit apart with a t15 torx screw driver .
How do I take the handle apart on my Kenmore Progressive vacuum model 116.21614011? I removed the screws but it won't come apart.
There are catches that snap the handle together. It's hard to separate the handle without breaking the catches. Replacement may be required
1helpful
The outside door handle won't open the door
Either the rod between the exterior handle and the catch has popped off. Or there is a problem with the catch itself.
What is error statemant?
The try...catch Statement The try...catch statement allows you to test a block of code for errors. The try block contains the code to be run, and the catch block contains the code to be executed if an error occurs
Syntax:
try
//Run some code here
catch(err)
//Handle errors here
}try
catch(err)
1helpful
My door catch on the front passenger side is stuck in a strange lock position and now I can't even shut the door. to be noted the interior door handle for that side did not work this is an 8th generation...
If I understand you correctly and I think I do, the door catch or sometimes called "door check"can break. When this happens the catch rod comes out of position and wedges against the door jam. The door catch will have to be replaced. The door panel will have to come off to replace it, so while your in there you can reattach the inner door handle cable back into place to fix your inoperative inner door handle concern. -hope this helps.
2helpful
2001 frontier tailgate won't open
Remove the inner pannel. Then move the handle the connecting rod from the handle to the lock will move.Then pull or push the connecting rod helping the handle. When you get it open move the handle again if it moves freely then most likely the catch needs adjusting to adjust loosen the screws aroung the catch on the rear pannel move the catch out a little try closing the tailgate if it takes undue force to close then repeat moving the catch out until it is easy to shut simple rule is if it is hard to close then it will be hard to open! Leave the inner pannel off until you can easily open the tailgate with the handle as you may have to give the handle a helping hand to open until you have finished adjusting.
4helpful
Door handle of washing machine broken
if clothes are still in washer? and machine has finished cycles? then handle broke so unable to open ??? your best option is to unplug/ and if necessary disconnect water supply hoses then remove the top screws from rear panel which also secure the top panel as you will observe ? then pull backwards top panel and loft off ? you now have access/visual of the door catch inside front machine look?? at the catch and you will see how it locks ? you can lever the catch gently and door opens to fit a new door catch is easy diy and not expensive if you are confident usual problem these break ? is the time delay micro switch sticks with age /moisture try dw40 and work plunger b4 you refit door back after replacing handle/catch assy
12helpful
Folding the pliko matic
To fold the Pliko, first the both handles have to be pulled out. To do it, grab the plastic (1) which is just under the handle (with a little hook on it), and pull it upwards. Pull the whole handle upwards, so it gets out of the catch situated near the front wheel (2). Do the same with the other handle (maybe it is possible to do it with both at once - I'm not sure yet). And then lift the back handle (3) (between the rear wheels) up, folding the pushchair. To lock it folded, you have to use the same catches, which had to be released earlier, to hold the handles - but this time they catch the handles somewhere in the middle (4).
Top Bugaboo Baby Gear Experts
Jennifer Rock
Jennifer Rock
ZJ Limited
ZJ Limited
john h
Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
