If your soundbar has bluetooth technology in it, turn it to the input of "Bluetooth" or "BT". In your TV's smart menu, you should be able to find bluetooth settings, and be able to find the soundbar from there. If you are looking to connect it by a cable, you will have to connect a digital optical cable into the back of the TV, and run it down into the soundbar to receive sound out of it.
Because your TV is not Bluetooth-enabled and you are trying to connect it to a Bluetooth-enabled soundbar via Bluetooth. There are other ways to connect your TV to the soundbar:
1. analog AUDIO OUT (L/R) of your TV to the AUX IN on the soundbar (use a 3.5 mm.-to-RCA audio cable).
2. Optical OUT on your TV to Optical IN on the soundbar.
3. HDMI port to HDMI port (this may not work if your TV is not ARC compliant you have to try).
You get better sound quality with option 2.or 3. (if this one works for your TV)
Here is the link to download the soundbar's User Manual for help with the connections:
I suspect that the TV you have does not support the ARC function that the sound bar has. What you may have to do is use the Optical In from the sound bar to the TV and you should be good to go. You may have to change the TV's settings to use the Optical In though. So you should end up with the BluRay Player connected to the TV via an HDMI cable, the sound bar connected to the TV via the Optical In using a fiber optic cable. Hope this helps.
Generally, connecting phones via bluetooth to a laptop just allows for file transfer between the two devices. It is not to input sound from the phone through the speakers of the laptop. You would need a bluetooth audio device for that such as bluetooth speakers or headphones
any sound bar will work. i have a LG 50" with a Samsung sound bar with a optical audio wire going from my tv to the sound bar. it comes with a bluetooth sub woofer and it sounds great.
bluetooth is a type of wireless connectivity between supported devices. you can share music files with other mobile users through bluetooth , and you may use a bluetooth wireless headset to listen to the music files being played through your bluetooth enabled systems such as laptop and may also be supported by yuor phone.
