Konica Minolta bizhub C250 All-In-One Laser Printer Logo
J
Jose Gonzalez Posted on Dec 14, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error code T81 - Konica Minolta bizhub C250 All-In-One Laser Printer
Norman Weimar
Level 3:
  • Konica Minolta Master 7,035 Answers
  • Posted on Jul 09, 2016
Norman Weimar
Level 3:
Answers
7035
Questions
Helped
1914106
Points
11960
Check your fax line
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
How do I fill up the ink on my Epsom TM-T81?
Hi, there is no need for ink for this printer. it's a thermal printer, you have to use thermal paper with it.
T81 error minolta C452
fax error code
Epson tm t81 can not gives test print and shows state is invalid
If epson tmt 81 is not printing test page then check for dip switch below the printer and also reinstall the printer driver & configure the port properly
Xp driver download
for printer TM-T81 Epson error shows state is invalid
3helpful
Can I connect an Epson TM-T81 to my iMac computer?
That's the problem with Apple, they live in there own little "trendy overpriced" world, but I don't mean that in a bad way. That said, Try here: http://www.epson.co.in/epson_india/support/product_compatibility.page? Happy Holidays.
2answers
I am using Epson TM T81 thermal printer and it is showing status USER INTERVENTION REQUIRED , printer is not printing document. I uninstall drivers and install it again it works but whenever I restart the...
Sir/Madam
i suggest You download Epson Printer Driver From official Epson Printer Website and Perform Below Following Step Mention On Epson website on Below, i hope You Fix Your Epson Printer problem,
1. About this software This package includes the following two software programs to use with an EPSON TM-T81 printer. 1) Windows Printer Driver This driver is a Windows Printer Driver for the TM-T81 printer. This driver makes it possible to print from a Windows application.
2) StatusAPI StatusAPI is a program that works in conjunction with the TM-T81 printer driver. It offers an Application Program Interface for obtaining the printer status whether or not the printer is printing. This API makes integrating printer status handling functions with applications more simple. For detailed information, please see each reference manual. The driver operation has been verified with the following operating systems. Windows 7 Ultimate SP1 32/64bit Windows Vista Ultimate SP2 Simplified Chinese 32/64bit Windows XP Professional SP3 Simplified Chinese 32bit Windows Server 2008 R2 Enterprise SP1 64bit Windows Server 2008 Standard/DataCenter SP2 Simplified Chinese 32bit Windows Server 2008 Standard SP2 Simplified Chinese 64bit Windows Server 2003 R2 Enterprise SP2 Simplified Chinese 32bit Windows Server 2003 R2 Standard SP2 Simplified Chinese 64bit Windows XP Embedded 32bit SP2 Windows Embedded Standerd 2009 32bit Windows Embedded POSReady 2009 32bit This driver is not supported by Windows 95/98/NT/2000 and Windows XP 64bit. EPSON IM series PC or IBM compatible PC Supported Printers EPSON TM-T81 The printer driver operates regardless of the pritner firmware version. 2. Supplied Files APD_415bSC_T81.zip : Printer Driver,StatusAPI installer with manuals Refer to the installation manual APD4_T81_Install_SC_RevE.pdf. 3. Remarks - For detailed information, please read each manual that is created by the installation. -When an error message is displayed during installation, the following procedure may enable to recover from the error. 1) Specify the uninstall option, and execute the installer "APD_415bSC_T81.exe /uninstall". 2) Remove the error factor.
3) Execute the installer "APD_415bSC_T81.exe". -Characters may not be printed correctly when using Easy Print of Windows Server 2008. For detailed information of this problem arising from the operating system, see the following web page provided by Microsoft Corporation.download epson biz com
Or If You Still Need Epson Printer Help Then Follow Us On:
Epson Printer Support
HOW DO I LUBE MY HORIZON T81 TREADMILL
Your lube goes between the walking belt and the deck( the board under the belt). Apply lube as close to the center of the belt as possible then walk at a slow speed to spread lube evenly.
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
