SOURCE: Hand held scanner LS2208
At the Symbol web site they have some instuctions for programming a 'Tab' at each scan.
Follow this link....
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=11124&sliceId=SAL_Public&dialogID=58352294&stateId=0%200%209199403
SOURCE: Barcode scanner scans and beeps, but will not put the numbers in the computer
There is more than one way for that imager to send data to the computer. Are you using USB, serial, or is there a little box that goes between your existing keyboard and the PC that accepts the scanner connector?
SOURCE: Enter function
Hi Lee, It can be done by programming the scanning the 'Send Enter Key' barcode twice, from the owners manual. eg Scan the barcodes - Send All Data, Send Enter Key, Send Enter Key, Save
SOURCE: Scanner does not automatically enter barcode,
I had this problem as well, and I found the fix! Go to this site:
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=7188201dpdf&sliceId=&dialogID=191796267&stateId=1%200%20191788707
It is the link to the PDF support for the scanner. It has barcodes you can scan to program the scanner to press enter or tab when it is done!
SOURCE: Symbol LS 4000i scanner issues
it looks like the scanner lost the settings. As power is there, so connection is ok. The several (four) beeps after reading the barcode means communication error.
Please try to find the original sheet with configuration barcodes or download it from support.symbol.com website, you would need to scan the barcode for IBM PC/AT & IBM Compatibles from Keyboard Wedge Chapter.
