20 Most Recent
CIPHERLAB 1000 Handheld Barcode Scanner Questions & Answers
I cannot get it to
Please give us the type of computer or system you are trying to hook it to and what exactly have you tried please.
I have got scanner 1000 but cannot scan the
Hi there, you may check the settings of your scanner software, go to start>programs and check the scan software utility and from there check the settings of the scanning page/are so that it would see those barcodes you need.. or may lighten the scan settings as well.
Extra zero
The default setting for this scanner is EAN13 enabled. This means that all 12 character barcodes will be changed to 13 characters by adding a zero in front.
How to Disable:
Open the manual that came with the scanner (it's available to download on the Cipherlab web page if you don't have it).
Find the UPCA Parameters barcodes (currently page 29). The next heading down is Convert to EAN13. You will see the disable and enable barcodes.
1) Scan Enter Setup Barcode (on practically every page of the manual at the bottom). The scanner will beep 6 times.
2) Scan the Convert to EAN13 Disable barcode. The scanner will beep once.
3) Scan the Update barcode at the bottom of the same page.
Your scanner should now read both 12 and 13 character barcodes correctly.
Hope this helps:)
CIPHERLAB 1000 (serial ) Driver for WinXP
you dont`t have a driver for serial comm.open hyper terminal on com port where is the scaner.read a code and you wilkl see the numbers on the screen.If you want to work with some windows programs change that barcode for usb or ps/2 variant.
Hi, my Cipherlab 8000 turned off while I was working and now, after so many attempts, it doesn't turn on anymore, what can I do?
what is it? is it a computer posted to computers.
huge 200page manual (first google hit )
its a system , not 1 thing, right,
a host and mobile computers.
which of these is your system.
Receiving in Retail
Price Check
Product labeling & Tracking
Shelf Product Replenishment
Mobile Point of Sale (POS)
Mobile Inventory Management
Order Picking & Staging
Work-In-Process Tracking
Material Flow Control
Transportation & Distribution
Warehousing
Asset Management
what part of the system are you hands touching, IDK>
12/17/2019 2:26:17 PM •
CIPHERLAB...
Answered
on Dec 17, 2019
Can't figure out scanner
with most barcode readers you need to configure it before you can use it, this is usually done via a barcode book whiich configures everything that the gun can do....everything from how it communicates with the pc, to the types of barcodes it can scan
5/9/2011 12:21:03 AM •
CIPHERLAB...
Answered
on May 09, 2011
