20 Most Recent Datalogic Gryphon I GM4100 Barcode Scanner PN GM4130WH910K1 Barcode Scanner Questions & Answers
Page 80, Section GS1-128 AIM ID Section of Product Reference Guide (PRG), Gryphon I GD4100/GBT4100/GM4100 and Gryphon L GD4300 (English)
Manuals
Datalogic... | Answered on May 05, 2014
1. Download Product Reference Guide (PRG), Gryphon I GD4100/GBT4100/GM4100 and Gryphon L GD4300 (English) Manuals .
2. Go to Page 80, Section titled GS1-128 AIM ID.
a. Scan the Enter/Exit Programming Mode code.
b. Scan the GS1-128 AIM ID=Disable code.
c. Scan the Enter/Exit Programming Mode code.
I am not sure you can add a pause in the Prefix per se, but you can increase the Intercharacter delay which should achieve the result you want.
Download the Product Reference Guide for the GM4100 from this page: Gryphon GD4100
Here is the direct link to the 13MB PDF:
http://www.datalogic.com/tools/download.aspx?iddwnfile=1608&path=%2fupload%2fmarketlit%2fmanuals%2fgryphon%2f820050514.pdf&name=820050514
You will need to print several pages so that you can scan the appropriate codes to change the scanner setup. Follow the instructions on the following pages:
Pages 47 and 292 describes the Intercharacter Delay.
Pages 351 and 352 in Appendix D give you the number scans you will also need.
You might start with a 10ms delay and increase this until it works. A little experimentation will surely solve your problem.
Datalogic... | Answered on Feb 02, 2015
Just download print the GRYPHON quick reference guide (print on laser printer without zooming) and program the scanner to factory default.
Otherwise, you will need to download the FULL reference manual. Then print out the relevant programming barcodes that will remove the last character.
Datalogic... | Answered on Dec 23, 2013
Here's the link for the manual, though I didn't see direct instructions on how to set display brightness:
https://www.elzab.com.pl/download/io/FalconX3instrukcjaObslugi.pdf
I saw on Page 50 the Display icon on the desktop. As this is a Windows CE operating system environment, most likely the display brightness can be adjusted there.
Hope this helps, I don't have specific working knowledge of this particular device.
Datalogic... | Answered on Feb 07, 2019
Reset tbe scanner and again program the scanner for your required configuration.
Datalogic... | Answered on Apr 18, 2018
Datalogic Gryphon I GM4100 Barcode Scanner  PN GM4130WH910K1 Barcode Scanner Logo
3 questions posted
Top Datalogic Computers & Internet Experts
Mike Story
Level 1 Expert
Paul Bade
 Ian Kayhan
Ian Kayhan
Are you a Datalogic Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Gryphon Datalogic
  • Gryphon Datalogic
Most Popular Question
gryphon gm4100 ean 128 c1 identifier
  • Computers & Internet
