20 Most Recent Datalogic Gryphon D200 (901661076) Handheld Questions & Answers
Scanner isn't scanning all the time
It doesn't sound like a power issue. Most likely it either needs cleaned, or it needs the laser recalibrated or replaced. Try cleaning the glass for starters, and then hold the scanner about two inches from a white piece of paper. You should get a solid, bright red line. If the line is distorted you need to recalibrate the laser. If it's dim, the laser unit is going out. The laser can be replaced, but I don't know if it's one of those things where the part plus labor costs more than replacing the scanner.
8/28/2007 4:38:13 PM • Datalogic... • Answered on Aug 28, 2007
How do I add a pause in the prefix of Barcode scanner GM4100?
I am not sure you can add a pause in the Prefix per se, but you can increase the Intercharacter delay which should achieve the result you want. Download the Product Reference Guide for the GM4100 from this page: Gryphon GD4100 Here is the direct link to the 13MB PDF: http://www.datalogic.com/tools/download.aspx?iddwnfile=1608&path=%2fupload%2fmarketlit%2fmanuals%2fgryphon%2f820050514.pdf&name=820050514 You will need to print several pages so that you can scan the appropriate codes to change the scanner setup. Follow the instructions on the following pages: Pages 47 and 292 describes the Intercharacter Delay. Pages 351 and 352 in Appendix D give you the number scans you will also need. You might start with a 10ms delay and increase this until it works. A little experimentation will surely solve your problem.
2/2/2015 6:35:02 PM • Datalogic... • Answered on Feb 02, 2015
HOW I WANT TO DISABLE ENTER AFTER I SCAN BARCODE..... I USE SCANNER MODEL GRYPHON GD4400
Just download print the GRYPHON quick reference guide (print on laser printer without zooming) and program the scanner to factory default. Otherwise, you will need to download the FULL reference manual. Then print out the relevant programming barcodes that will remove the last character.
12/23/2013 9:48:06 PM • Datalogic... • Answered on Dec 23, 2013
How to adjust the brightness on Datalogic Falcon X3+ handheld?
Here's the link for the manual, though I didn't see direct instructions on how to set display brightness: https://www.elzab.com.pl/download/io/FalconX3instrukcjaObslugi.pdf I saw on Page 50 the Display icon on the desktop. As this is a Windows CE operating system environment, most likely the display brightness can be adjusted there. Hope this helps, I don't have specific working knowledge of this particular device.
4/2/2024 10:36:21 AM • Datalogic... • Answered on Apr 02, 2024
Quickscan QD2430 Insert Pause and Enter after Scan
Gryphon™ Family
Datalogic https://www.datalogic.com > marketlit > manuals PDF settings before scanning the ENTER/EXIT barcode a second time, which will then accept your changes, exit Programming Mode and return the reader to normal ...
5/5/2023 3:32:59 AM • Datalogic... • Answered on May 05, 2023
Configuring (changing) barcode reader suffix
Reset tbe scanner and again program the scanner for your required configuration.
4/18/2018 1:51:58 PM • Datalogic... • Answered on Apr 18, 2018
2answers
Straight talk troubleshooting
The best thing for you to do is call straight talk and they will talk you through it. It is free of charge and they are very helpful when it comes to that stuff. It could be the network in your area that is the problem. Straight talk will and can check for you.
10/25/2014 3:53:18 AM • Datalogic... • Answered on Oct 25, 2014
0answers
Not scanning
Be the first to answer 6/10/2014 12:39:16 PM • Datalogic... • Posted on Jun 10, 2014Be the first to answer
I have 2d barcode scanner but i have no product number
hey,sorry for my late reply! which type you used, i just know this data matrix 2D barcode reader
11/4/2013 7:13:29 AM • Datalogic... • Answered on Nov 04, 2013
I scan barcode into notepad ....computer goes haywire
heare are the manual but i search a manual whear i can enable the code 93, has any a idea?http://www.barcodemuseum.com/Datalogic/Manuals/dlc6000_820000512.pdf
1/21/2011 11:03:59 AM • Datalogic... • Answered on Jan 21, 2011
I have a PDT6846 that
My first thought is that your firewall or virus software is blocking it. try shutting it down and see if it works then.
3/11/2010 11:43:36 AM • Datalogic... • Answered on Mar 11, 2010
2answers
Implementing Reliable WordPress Website Backups: A Solution to Downtime and Errorsi wan
Keep a backup on your hard drive or a backup. The backup system is a free service supplied by your internet provider. If you use it daily or after every update, there will never be an issue.
4/16/2024 12:14:38 AM • Computers &... • Answered 4 hours ago
Do u guys know some good custom web app development services?
As far as I know, Digiteum is one of the best custom web app development services https://www.digiteum.com/web-application-development-services/. They offer comprehensive solutions tailored to clients' needs, with expertise in building innovative and scalable web applications. You might want to check them out for your project.
4/15/2024 11:23:03 AM • Computers &... • Answered 17 hours ago
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired anemployment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut. They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
4/15/2024 4:17:35 AM • Computers &... • Answered 24 hours ago
How to get free backlinks?
YouTube Backlink Generator https://ovdss.com/apps/youtube-backlink-generator
4/13/2024 3:06:42 PM • Computers &... • Answered 2 days ago
Solitaire master has a hang
clarify pi please. if you meant pi to mean main screen picture, you probably have used up your free time on this program.
4/13/2024 2:31:14 PM • Computers &... • Answered 2 days ago
3answers
How i free download tally
u need tally 4.5 free software (full ) if u need mail me i will give u link k
4/13/2024 2:20:33 PM • Computers &... • Answered 2 days ago
We have a Dukane Model No ACC5 Administrative Control Console and it keeps chirping. Not sure why or how to make it stop. Please advise?
This fault / alarm / warning is not listed anywhere and the company is no longer in business. Turn over the console and see if there is a door for a back up battery. It may be warning that it is running out. Do the same with the main control unit. You could also try powering off the main unit for 10 minutes to reset the software. https://www.google.com/search?q=dukane+model+no+acc5+administrative+control+console+chirping This is the unit that drives your admin console http://serialsistemas.com.br/duk/2/85101-0025%20--%20MCS350.pdf ..
4/12/2024 2:30:20 AM • Computers &... • Answered on Apr 12, 2024
2answers
To check if my sasseta certificate is registered
http://www.sasseta.org.za/ SASSETA Branch Contact Details Telephone Numbers: Call Centre: 27 (0)11 087 5555 Fax Number: 27 (0)11 205 0046 Switchboard: Midrand E-Mail: [email protected] Address & Map: Midrand Office Physical Address: Riverview Office Park Janadel Avenue (off Bekker road) Halfway Gardens Midrand 1685 Postal Address: P.O. Box 7612 Halfway House 1685 http://www.sasseta.org.za/content/tinymce/plugins/openfile/uploads/FRM_SKA_004_Application%20for%20Certificate%20Re-Issue.pdf
4/12/2024 12:53:51 AM • Computers &... • Answered on Apr 12, 2024
Datalogic Gryphon D200 (901661076) Handheld Logo
3 questions posted
Top Datalogic Computers & Internet Experts
Paul Bade
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Datalogic Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Gryphon Datalogic
  • Gryphon Datalogic
Most Popular Question
scanner isnt scanning all time
  • Computers & Internet
