La Crosse Technology TX38U-IT Wireless Temperature Sensor Logo
A
Anonymous Posted on Dec 08, 2013
When I have the outdoor senser in the sun to charge the batteries it gives false outside readings. Can you have it in the sun or does it have to be in the shade?
OUTSIDE TEMP SENDING UNIT GOT WET AND WILL NOT CONNECT TO CLOCK. HOW CAN I FIX OR HOW CAN I REPLACE?
[PDF]WS-8117 ATOMIC CLOCK WITH OUTDOOR WIRELESS ...
https://www.lacrossetechnology.com/products/.../misc/8117-manual.pdf
NOTE: Do not set the clock until the outdoor temperature is displayed. .... The unit will still try and receive the signal every day despite it being manually set. ..... sunlight, extreme cold and wet/moist conditions as these will lead to rapid changes ... Beforesending the atomic clock in for repairs, contact La Crosse Technology.
La Crosse Technology Top Solutions
https://www.lacrossetechnology.com/support/top_solutions.php
A: Complete a restart for display with the temperature/humidity sensor: ... to rest for 15 minutes can result in failure to connect with the outdoor sensor or missing ... Products set outside of these time zones will not search for a WWVB signal as it is ... locate the Clock or Weather Display near an outside wall and point the unit in ...
Common issues weather stations: Click Here
www.weather-station-products.co.uk/faqs/common-issues-weather-stations
Under £30 £30-£75 £75-£125 From £125 Birdhouses/Feeders Outdoor Clocks ... I'mnot getting any outdoor readings from my outdoor sensor, what do I do? This willcure 90% of all sensor connection problems, important you must ... is the airtemperature, to get this reading you need to place the unit away from direct sun.
Replacement Temperature Sensor ' AcuRite
www.acurite.com > All products
1helpful
Hi, I have a new ryobi touch start weedeater. I have used it twice. I charged it overnight for first use. It worked fine. After 2nd use ran out of charge so I re charged it . It doesn't seem
If it doesn't seem to be recharging or taking a full charge, check the charging jack to make sure no foreign object (leaf debris, etc) got into it. If it is clean, then you probably have a warranty issue with the battery or charging system.
Note: do not leave the string trimmer out in the sun or outdoors in cold weather while it is charging. The charging process only works properly at room temperature. In particular, lithium batteries are very finicky about charging conditions. Charging overheated lithium batteries can cause a fire, so they have a safety circuit to prevent charging outside the proper temperature range.
I have eight atomic clocks,none of them have the outside temperature working,all have new batteries???
If your outside temperature is not showing on your clock, that may mean that the clock and the transmitter have lost their connection. To reconnect them you must first take the batteries out of both of the units for 15 minutes. First put the batteries back into the transmitter, and then the clock. Let them sit side by side inside your home. When both the indoor and outdoor temperatures show on your clock with the same reading, or within two degrees of each other, then you may put your transmitter back outside. Remember to keep the transmitter out of the direct sun in a dry place. Also keep it away from metal, which can affect the readings.
Radio Shack 63-1090 indoor/outdoor temperature unit. Won't give outdoor readings. Temps are cold, -5F but it always worked before. Put in new batteries in the inside and outside units, wiped outdoor sensor...
Did you reset the sensors after replacing the batteries? Bring the sensor inside and close to the main unit. Replace batteries on both units. Use a thumb tack and stick it into small reset hole near battery compartment to reset both units. If that doesn't work, your sensor needs more troubleshooting or needs to be replaced.
I have a Springfield precisetemp 433 wireless. The outside temp is reading 99 degrees when it should be reading about 70. When I disconnect the unit from the probe the temp is correct, so I'm guessing...
SOMETIMES WHEN METAL IS IN DIRECT SUNLIGHT IT WILL
GIVE FALSE READING. MY OUTDOOR THERMOMETER IS METAL AND IT READS ABOUT 15 DEGREES HOTTER THEN IT IS. BECAUSE IT'S IN DIRECT SUNLIGHT.
1helpful
Outdoor display doesn't work
My clock display of the outdoor temp is only blinking and not display the the temp. I have the senser put in in outdoor window. The senser shoes the temp but is not carried over to the clock. Ive put in new batteries and have the senser in the correct distence from eachother. Why is the clock contunue blinking outdoor temp.?
MY BATTERY WONT STAY CHARGED. HOW DO I GO ABOUT TROUBLE SHOOTING.
Battery problems are usually caused by too long a charge with electricity, thus exceeding the load. try drying the battery in hot sun for a while, then try to use. usually successful.
My oregon scientific indoor outdoor weather station with atomic clock just stopped picking up the outdoor readings, it won't switch to that channel any longer. tried removing and reinstalling the battery,...
I had the same problem, Since the outside temp wouldn't read, I figured it was the outside unit batteries. Went through half a dozen AAA batteries and wouldn't read. It was the indoor unit. Had the same bats I installed 3 years ago. DUH! Replaced the AAA, and all was well. When the inside batteries die out, it has just enough juice to read indoor temp, but not enought to sense exterior signal.
24helpful
2answers
Thermo clock RAR312 not picking up outdoor transmitter temperature. Replaced battery but still nothing.
take a paper clip and reset the reset button located in the battery compartment. Then, try each of the 3 channels until you get a reading in the outside temp field. Wait a good couple of minutes at each channel setting before determining the units are not pairing. Do this with the units side by side for signal acquisition, then once acquired, move the remote sensor outdoors. Hope this helps!
Outside unit not registering temp and humidity to base unit
Uniden EWCI936
To get the outside temperature working again, open the outdoor sensor box carefully loosening the one screw with a screwdriver, insert 3 brand new AA batteries, check phone for outside temperature. If not showing on the phone display, try changing the 'channel' setting, just above the batteries. Be careful not to break the tiny switch. Gently use a smaller flathead screwdriver, if needed. There are 3 settings. Mine worked fine on the first setting. If it is showing on the phone set screens, then, carefully screw the lid back on to the sensor box, and re-insert into the sensor wall holder. I keep mine in a plastic bag on a shelf outside, away from sun, so I can get a true reading day or night. It is always a bit warmer in the sunlight than the true outdoor air temperature. Enjoy
Top La Crosse Technology Measuring Tools & Sensors Experts
Ngoro
Are you a La Crosse Technology Measuring Tool and Sensor Expert? Answer questions, earn points and help others
