20 Most Recent La Crosse Technology La Crosse C86234 Wireless Weather Station Questions & Answers
We are having the same issue. How did you get this resolved?
La Crosse... | Answered on Jul 06, 2015
Replace the glass reed switch on the circuit board as it is bad. You must be very careful to orient the replacement switch so that it closes only when the rocker arm is at the vertical position. This will take some work to get right. Use a volt ohm meter and set the Plus lead at the reed switch lead at the top of the board. The meter should show a closed circuit only when the rocker is at the top. Good luck.
La Crosse... | Answered on Jan 16, 2014
The WS-7395U uses the La Crosse TX8U outdoor temperature and humidity sensor. That part has a $49.99 MSRP. It is $46.95 from La Crosse; see http://www.lacrossetechnology.com/tx8/index.php to order the part. Other vendors that I checked do not have the sensor in stock for sale separately.
I hope this helps.
La Crosse... | Answered on Aug 21, 2013
They are advertised as 50 foot range, but the accuracy starts falling off past about 35 feet
Measuring Tools... | Answered on Oct 11, 2019
A hookah is an instrument used to smoke shisha. Shisha is a type of flavored tobacco! Read more on Shisha Heart
Measuring Tools... | Answered on Oct 10, 2019
can the battery be replaced. If so, how?
open the cover on the back of the device. this is done by squeezing the cover of the battery sector slightly. then remove the old batteries and replace the new ones (I assume you have the AAA) and put the new ones in keeping with the polarity for the device to work properly and then close the battery compartment cover in reverse order
Measuring Tools... | Answered on Sep 29, 2019
La Crosse Technology La Crosse C86234 Wireless Weather Station Logo
Popular Tags
11 questions posted
Top La Crosse Technology Measuring Tools & Sensors Experts
ka4iup
ka4iup
Are you a La Crosse Technology Measuring Tool and Sensor Expert? Answer questions, earn points and help others
View Most Popular
  • La Crosse Technology Measuring Tools & Sensors
Most Popular Question
rain gauge not working
  • Measuring Tools & Sensors
