FIRST, if this code comes back. Have a technician look at it DO NOT CONTINUE TO RESET the code!!!! AS this is for the Hot Part called the FUSER. It can catch on fire! And that will ruin a perfectly good day!!!!
The soft switch you want is 03 -1-0
with the code it will be 03-1-1
1. "Service mode menu screen"
Press [07 System Setting].
2. "System Setting menu screen"
Press [01 Software DIPSW Setting].
3. "Software DIPSW Setting screen"
Press the [?], [?] or the numeric keys to select DIPSW bit number.
4. Press [On (1)] or [Off (0)] to set the selected bit number ON/OFF.
5. Press [Return] to return to the "Service mode menu screen" on which the sub menu was displayed.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: bizhub 350 error code
c3852 means low fuser(hot section) temp setting. hold down utility or stop key, then you should be abel to do trouble reset. if problem persist it would most likely be a lamp or a sensor, which will require a technician to come out.
SOURCE: Konica Minolta Bizhub 920
the copier recognised the paper,but when printing/copying the feeder doesn't pull the paper and on the machine it says paper misfead,open front cover.
SOURCE: konica minolta bizhub 920 error code sc 46-16 pl
konica minolta biz hub 920 error code sc 52-09
