SOURCE: dryer
Your issue is;
Hotpoint (Frigidaire base), model No. NLL113EYWO," my dryer make a scraching noise when it first start and some time"
Thank you for providing a valid model number!
Following this link, http://www.repairclinic.com/SmartSearch/SmartSearch.aspx, provides valuable D.I.Y. safety information on the make and model number of your appliance. In order to access your product information, you will need to enter the model number stamped on the manufacturers product information data tag, located on the unit, and not in the User’s Manual.
All disassembly procedures for a Frigidaire base dryer can be found at this link: http://www.repairclinic.com/0100_20.asp
1. I would check this first: Front drum glides:
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=274452&PPStack=1
2. This link will show the rear drum bearing assembly.
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=771336&PPStack=1
3. This will show the upper seal assembly.
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=947963&PPStack=1
4. This will show the lower seal assembly.
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=947964&PPStack=1
I hope this helps resolve your dryer issue.
Please show your appreciation by rating my solution.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
SOURCE: long time to dry clothes
The dryer has one of its rows of heaters open. Open up the dryer and check the coils behind the drum. read more
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: My dryer makes a buzzing noise when I push the start button
My Hotpoint dryer is seven years old and did the exact same thing. When I got over the anger and the thought of spending 4 or 5 hundred dollars to replace it I started messing with it. I finally decided that since it buzzed when I tried to start it there was current there. The only other thing it could be was the drying cycle knob.
I held the start knob and let it buzz while I slowly turned the dryer cycle knob to the right. As I turned through each cycle it would hit "off" and the buzzing would stop and then resume as I moved past the "off " setting. On the third trip around the dryer "started" and has been working since. Maybe something got out of kilter. Apparently the problem was in the knob that controls the drying cycles.
SOURCE: DRYER DOES NOT START ONLY MAKES BUZZER SOUND. WHEN
sounds like a motor these Do not use a starting capacitor, they use very small Gage wire for the start windings ..You can get a new motor for about 130.00 dollars if you decide to replace it I would advise you to also order a new blower wheel ,, after time the blower wheel has a way of seizing its self onto the motor drive shaft and 90% of the time you have to destroy the blower wheel to get it off it adds about 25.00 to 30.00 more to the job but you will be glad you did
