Control board got wet when gasket failed but still washer was still working when discovered. Gasket replaced but now how to get rid of scrolling message and beeping? Thanks
SOURCE: what is p3 code on hobart am15 dishwasher
It means that the final rinse thermistor is bad.Your not getting 180 degrees---right?Its located on the booster and costs about $65.I work for hobart.Any ?
SOURCE: HOBART AM15 DISH WASHER ERROR(E1)
are you sure you dont have a bad display, there are no e1 err. for the am15,e2,fill prob.e6sensor,ed,slow leak,ee, bstr not to temp.ef, iternal control err. if it displayed p1 that is an open or shorted wash thermister
SOURCE: The display on the hobart am 15 dishwasher when
Check thte drain hose as it might be clogged at the entry point to the drain if it connected to a garbage disposer.
SOURCE: How do you drain Hobart
With the door lifted up, there is a lever on the rear-right on the inside of the dishwasher. Lift this lever and the machine should drain. If it doesn't drain with the lever up, remove the screens inside the dishwasher and verify that the lever is, in fact, lifting the overflow tube so that water can drain out the bottom.
