Re: power lite blinks 10 times. no pic no sound. cant...
Red light flashes 4 times then stays on for about 5 seconds then flashes 4 times again any idea what this means and how i can fix it tv is about 4 years old and only just started doing this
? 8:35
https://www.youtube.com/watch?v=iHBIiRxhe0w
Sep 26, 2014 - Uploaded by ShopJimmy.com
Panasonic Plasma 14 Blink Code Explained with Repair Info How to ... I guess I'll try the SC board and if that does not work simply save up for a new ... The red power led was flashing 12 timespause a few seconds then flash 12 again. ... It powers up and shows the green power light is on, but there's no ...
Oct 24, 2015 - More about : power light flashing wont turn ... December 20, 2013 10:12:55 AM ... sound like it is coming on then it shuts off and the red power light flashes slowly. ... 50in Plasma tv power light is flashing 8 times and won't turn on. ...tv to come on bcause the power button keep blinking my tv will not come on.
the green is the reboot process and is normal. the red light is an error code indicator. count the blinks of the red light...it cant be 30 times (I think) it will blink a sequence, pause, then do it again for a total of three times. count carefully, it gives you three chances to catch the number it is blinking.
The
power light keeps flashing and the tv won't turn on. If you unplug for a
minute and hit the power button it sound like it is coming on then it
shuts off and the red power light flashes slowly. The TV is a Panisonic
1080i HDTV, about 6-7 years old.
9.2. Power LED Blinking timing chart 1. Subject Information of LED Flashing timing chart. 2. Contents When an abnormality has occurred the unit, the protection circuit operates and reset to the stand by mode. At this time, the defective block can be identified by the number of blinks of the Power LED on the front panel of the unit. 26 TH-42PZ77U: There are different patterns for blinking light... 10 times indicate DG board problem - SUB 5V SOS, MAIN 3.3V SOS, DTV 9V SOS and Tuner Power SOS.
Since the TV is still receiving power, the problem is going to be with the TV's mainboard. After you unplugged the TV and plugged it back in, you said the power light went out again, so I assume the standby light wasn't flashing again? The flashing standby light is indicating an error code so my suggestion is to contact Sony for service options regardless if there is a warranty or not because service is the only solution to this situation. Don't forget to provide them the error code or 4 flashes repeating.
I think this sounds like my problem (need to replace the projector lamp). However, when I hit the "on" button, my SXRD 50" blinks green for about a minute then starts blinking red. Can you confirm the bulb solution? I was very pleased with this sight when my fan malfunctioned. I got the fan in a matter of day's from Sony and it fixed that problem.
