Moisture sensor works, drum spins, control panel lights but no heat in any manual or automatic setting
SOURCE: dryer spins counter clockwise
When installing new belt the belt comes off the right side of the drum and through the idler and around the motor shaft, then up the left side
SOURCE: Whirlpool duet electric dryer - drum turns; no heat
Turn off the breaker and check the heating element.
for more help go to live chat.
hope this helps
len west
SOURCE: The heating compenent works, but drum won't spin
Have you checked the belt? That's generally the problem when a dryer stops spinning.
SOURCE: dryer does not release any heat
Is yours the gas model? If so I need you to look for some things. Open back door panel and see if while trying to light the igniter is glowing orange. Sea Breeze
SOURCE: whirlpool cabrio steam electric dryer has sensor light on and does not work
have a problem with my cabrio dryer its powered on but when i push start the sense like comes on and does nother whats the problem
