SOURCE: output
When you change the selector switch, do you hear the relays inside the unit? Is your muting button activated (found to the lower left of your volume knob)? Do you have speakers connected to A or B or both?
SOURCE: need unlock code for sony str-dg520 5.1
The HDMI inputs are pass through inputs only. The reciever cannot recieve any sound signals through the HDMI's. The reciever acts as a selector switch for the HDMI inputs only. Whatever input you have selected on the reciever is the one that is being sent through the output to your TV. The "unlock" display shows when there is no sound signal sent to the reciever. There is no code to unlock. This is the reciever's way of telling you that there is no sound being sent to it from that input. Since there is no sound being processed from the HDMI's, you need to hook up an additional audio cable from the device to the reciever (preferrably an optical cable). When the reciever recieves an audio signal, it will then "unlock". I know it is confusing. I had to look into this problem myself, so I'm happy to help. Higher end recievers will actually recieve and process sound signals from the HDMI's. When I bought this one I thought it was going to do the same. That's what I got for trying to save a couple bucks on the cheeper model! Although it is still a good reciever.
SOURCE: sony str-de525 system "protector" problem
You've blown it. It recognizes a potentally harmful situation and goes into protect mode.
SOURCE: how to hard reset a sony str-DE898
I couldn't find anything about a Lock Code in the manual but here's the general setting-reset procedure:
Turn OFF the receiver
Hold down the I/0 for 5 seconds - "PUSH ENTER" appears on the display
Press ENTER
SOURCE: My Sony STR-DE685 Receiver out of the blue now has
In receivers, there are different power supplies or power supply outputs for the receiver and amplifier sections so you can have separate failures with one area not affecting the other. From your description, I think the (probably lower voltage) section for the receiver has either lost a cheap filter capacitor or a regulator IC. Neither of these are expensive parts but I can't know what labor costs in your area might be. An honest tech shouldn't ask more than ~$100 US for that kind of repair.
